ssss sound from tweeters
Originally posted by Bass Mechanic
maybe you can take a pic of it or give me a model number and ill look it up online
Yeah I spent like 15mins looking for that jumper on my Kappas. I've come to the conclusion that the person who wrote the manual was smoking crack
The hissing sound might be interference getting into the signal. Do you still hear the signal when the engine is off?
Originally posted by steveng
what signal? im thinking can this be a problem of using old wires? i use the wires that came with the tweeters instead of 16 gauge. any thought?
http://manuals.harman.com/INF/CAR/Ow...OM%20FINAL.pdf
dont know if this will help but here is a copy of the owners manuel. they talk about some switch in the crossover.
everything is sealed inside the crossover. maybe like you said, i have to remove the seal to move a jumper. but logically, how would it be sealed if it meant to be adjustable?
Originally posted by igo4bmx
Are you sure it's not bad signals coming from a head unit? something in the settings of the gain or pre out is off IMO
Yeah, try re-grounding your head unit with a small fuse directly to the negative terminal on the battery and make sure the speaker wires aren't running in parallel with any power wires, just to start.
