installing subs need help...please
Old Jan 8, 2006 | 11:35 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
What would you like us to do? Let you give bad advice?
Old Jan 8, 2006 | 03:49 PM
burnrubber's Avatar
burnrubber
Nucking Futs
no
Old Jan 9, 2006 | 06:11 PM
BADTEGRA90's Avatar
BADTEGRA90
and to clear things up a cap will not solve the dimming problem it will only act as a band-aid if u get dimming get an high output alternator
Old Jan 10, 2006 | 03:22 AM
burnrubber's Avatar
burnrubber
Nucking Futs
it does help because it will supply the extra power the amp needs when the battery can't. it will also help to keep you from blowing up a alternator
Old Jan 10, 2006 | 09:46 AM
totalimmortal
MalleusMaleficarum
That is correct. Thats a caps entire job. To take strain off the battery/alternator. Once you exceed 120% of what the battery/alternator can provide, damage begins to occur.
Old Jan 19, 2006 | 07:47 PM
smokealot's Avatar
smokealot
Default about the cap
the hole point of the cap is that (this is comin right off the package) will stop headlights from dimming. if you have a cap in your system and you light and shit still dim, then somehow someway, your speakers are still pumpin to much power. either get another amp, or smaller subs. the cap is a power supply suposed to act as kinda a second battery.
Old Apr 12, 2006 | 11:21 PM
91tegB18c3's Avatar
91tegB18c3
the cap doesn't help the light dim at alot..the best if you want alot of power, get a high amp alternater...
i run two battery and a cap and my lights still dim.
Old Apr 13, 2006 | 12:21 AM
Misa's Avatar
Misa
Pic Whore
two batteries and a cap are useless if your tiny alternator cant power/recharge them
Old Apr 14, 2006 | 02:01 PM
First-Bass's Avatar
First-Bass
12 Volt Master
Unfortunatly untrue:
A cap is a storage center for power, it loads and unloads faster than a battery, it is ment to slow the draw from the battery, Not to stop the dimmimg lights, it is basicly food for your subs/amp.
If you are looking for somthing to stop your dimming lights you need to run a larger alternator, and additional batteries.
Your car was designed to work off the battery it came with, not a system as well.
Old Apr 19, 2006 | 04:40 PM
mishqua's Avatar
mishqua
Thank u I was waiting to see the right answer to what a cap does. Was starting to wonder Also the cap will draw more power faster thus making your lights dim further.
