head unit keeps cutting off
Old Sep 9, 2002 | 03:09 PM
RaN RaN's Avatar
RaN RaN
Originally posted by angry sol
how do i know if its going into protection? does it look like it just turns off
this is WiLL...
on your amp there should be a light that indicates if it is in protection mode. when the amp goes into protection mode, its usually something wrong with the power supply....
it usually turns off, then back on.....
so check for that light.
Old Sep 10, 2002 | 01:35 AM
Bl@ck's Avatar
Bl@ck
Sinner
Originally posted by RaN RaN
this is WiLL...
what he said. all reputable newer amps have the protection feature. anything from a bad ground to your speaker wires being shorted together could cause it to go into protection.
Old Sep 16, 2002 | 01:01 PM
angry sol's Avatar
angry sol
well thanks for all the help guys.. i went to autozone and got my battery tested like someone here suggested, it turned out my battery was the problem the whole time so i replaced it today now everything works great:thumbup:
Old Sep 16, 2002 | 03:38 PM
99AccordCoupe's Avatar
99AccordCoupe
If you're going to run your system off the battery with the engine off, get yourself a deep cycle battery. You'll easy empty out that new battery you got with the amp and headunit pulling all that power.
JOKERCUSTOMS
CRX & Pre 92 Civic
2
Nov 12, 2007 12:57 PM
cablepower_9
Sep 22, 2004 10:49 AM
cablepower_9
Sep 9, 2004 10:31 PM
paul99se
Sep 15, 2003 10:13 AM
