Just Got a Solabaric S12L5 Woofer for my Integra
What would be the set up? I was going to get two but i figured i was limited by trunk space??? What would you guys suggest?
What do you have, etc???
Depends all on your budget. Check out the first thread in this forum, pretty nice sound in some of those whips.
I have a set of 5.25" woofers and Xovers for sale, as well as a 2 ch amp. Check sig.
I am trying to find an amp to power my S12L5... My bro says I need a mono amp that handles 2ohm...
I found something that might fit that description...
"Rockford Fosgate P3001 - Rockford Fosgate 900 Watt Mono Amplifier"
Can someone verify if it is the right amp to power my sub up???
Here are the Rockford Fosgate P3001 - Rockford Fosgate 900 Watt Mono Amplifier specs...
Mono Amplifier
150 watts RMS x 1 at 4 ohms
300 watts RMS x 1 at 2 ohms
900 watts Peak output at 2 ohms
2-ohm stable
CEA compliant
Tri-Way capable
Variable low-pass crossovers (40-400 Hz at 12 dB/octave)
MOSFET power supply and output stages
MEHSA technology
TOPAZ noise-killing differential inputs
Selectable Punch Bass 0/6/12 dB Punch Bass boost at 45 Hz
Transana circuitry
NOMAD advanced protection circuitry
11"W x 2-7/16"H x 11-11/16"D
Mono Amplifier
2-ohm stable
CEA compliant
Tri-Way capable
MEHSA technology
Transana circuitry
I have 1 S12L5 powered by an audiobahn amp A8000T mono amp.
# 4Ω Mono : 400W x 1 RMS
# 2Ω Mono : 800W x 1 RMS
This is good enough to power that single sub.
my amp for highs is an audiobahn amp also.
