Help on Sony
Old Sep 4, 2002 | 12:29 PM
SlowCivicHmm's Avatar
SlowCivicHmm
Default Help on Sony
I'm looking to get the following...
http://www.crutchfield.com/cgi-bin/S...0&I=158XSHF600
http://www.caraudioexpert.com/produc...roduct_ID=1805
http://www.caraudioexpert.com/produc...roduct_ID=1989
Right now I have 3 Sony 6x9's in the back rear hatch cover....
The question is what amp should I go with to power the 2 Sony 10's.......either sony or fosgate....
now on wiring up the inside speakers.....should I get a 4 channel amp to hook up the 3 6x9s and the 6.5 component speakers?? or just a 2 channel amp for the 3 6x9's and leave the front components to the deck???
What Amps should I get??? Sony or Fosgate??
Any HELP would be great...thanx
Old Sep 4, 2002 | 05:46 PM
FrequencyAudio's Avatar
FrequencyAudio
I wouldn't leave to front components powered by the deck. In real life you are gonna see around 20-25 watts per channel out of the deck(always look to RMS not peak power). Seeing that I would go with the 4-channel (unless you get a seperate amp for the insides) only problem here is that you say you have 3 6X9's and you are adding 2 more sets of wires to the mix with the fronts's meaning you would need 5 channels. The solution I would go with in this case would be to power one of the 6 x 9's off the deck this way you don't HAVE to buy another amp. The only other solution would be to double up your channels on the amp running 2 speakers off 1 channel, I personally would not do that. As far as amps go I would suggest you stick with sony(since you seen to like them alot) maybe try the XM1600GXD, or XM2150GSX. If you are going to buy all those at once I will hook you up with a real good price, if not I can still beat all all the prices you seem to have so far. Here is my pricing:
Sony XSHF600G $250 shipped
Sony CDX-M730 $309 shipped
Sony XSL1046 $110 shipped(I can't beat their price on that they must have gotten a special purchase) If you get it all at the same time save on shipping and save some more $. On the sony amps I can do $180 shipped for the 2150gsx and $270 shipped on the 1600gxd. E-mail me if you have any other questions!
Old Sep 4, 2002 | 11:24 PM
SlowCivicHmm
Thanks bro....
So I'll need a 4 channel amp for 2 of the 3 6x9's and the front components......and another 2 channel for the 2 subs....got it....
I'm going too look into the amps...I'll ask more ??'s later..thanks..
Old Sep 5, 2002 | 09:18 AM
JonHsiung's Avatar
JonHsiung
u c l a
It's good to know that another board-user can hook you up with better prices than those you find. That's one of the few reasons why I keep coming back here.
As for your question, i think you could go with that audio setup you just described except that i believe that the amp can hook 3 speakers on 2 channels. (wiring diagrams anybody?) i'm not quite sure though, so dont try it until someone else tells you if there is a certain wiring diagram or if it sounds like crap.
i have a rockford fosgate 800Wx4 amp. it's pretty good, but i've heard a few that are better... and i know it should because it's hooked up to a pioneer HU and two 15" kicker subs (enclosed box )
Old Sep 5, 2002 | 10:00 AM
SlowCivicHmm
hmmm.....what would happen if I hooked up 2 normally and then take the 3rd on and take the + from one channel and the - from the other channel????
Old Sep 5, 2002 | 10:38 AM
SlowCivicHmm
How about this 4 channel amp for the front components and the 3 rear 6x9's....
http://www.caraudioexpert.com/produc...roduct_ID=1802
Old Sep 5, 2002 | 10:41 AM
SlowCivicHmm
Frequency: I'll defitnaly get the components from you....250 shipped is the cheapest I've seen...
110 for one sub or both???
The deck I can get for 275 locally...but I'll buy some other **** from you, don't worry..thanks for the help keep it coming...
How much for that 4 channel amp from you???
VegasJones
Engine Swaps, Tech & Tuning
13
Feb 28, 2005 11:46 AM
rcdmotorsports
92+ Civic/EL & Del Sol
3
Feb 26, 2005 06:40 PM
Whitelude420
Prelude
May 27, 2003 05:20 AM
loool69
Accord
Oct 17, 2002 09:47 AM
