Sound system and alternator
Old May 8, 2005 | 11:52 PM
Bmpn's Avatar
Bmpn
Audiophile
I was thinking the same thing, take the cap out.
Also make sure the connections on your battery posts are VERY secure. My buddy lost an alt in his Grand Am GT b/c his positive battery terminal wire was loose and it was causing the alt to think the battery wasnt charging enough and it was stressing it. He also had a system so that probably didnt help.
Just a few more things to ponder.
Old May 8, 2005 | 11:54 PM
Bmpn's Avatar
Bmpn
Audiophile
also, make sure you upgrade the 'big 3' wires under the hood. those being ALT to BATTERY wire, Battery Ground, and Motor to Chassis ground (IIRC)
Old May 9, 2005 | 01:14 AM
shitbrick's Avatar
shitbrick
the same thing happened to me in a 89 ford probe lx i used to have, i forgot to tighten the battery terminal and it kill my alternator and my whole car shut down.
how is a alpine deck and a 400w amp killin a alternator. i doubt the alternator is that weak. and why do you have a capacitor it's not needed.
Old May 10, 2005 | 04:52 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Originally Posted by WiLL
It depends on the condition and size of your alternator now, and the power that the amp will draw.
What car and what amp are you planning on using?
1998 civic ex.... im assuming stock alternator and the amp will probably draw sumwhere between 500-700 i think the amp i posted somewhere on this forum was roughly 600 watts.
Lemme see if i understand correctly the amp only draws power from the alternator and not the subs or do both draw power?
Old May 10, 2005 | 07:14 AM
b00gers's Avatar
b00gers
Anything connected to the battery is drawing power. And also, in terms of power, your amp draw amperages....not watts. A good way to tell is to look on the on-board fuses on the amp...that will give you a rough idea of the max it will draw.
Old May 10, 2005 | 07:57 AM
shitbrick's Avatar
shitbrick
i have hard time believing this little setup is killing the alternator. what brand of amp do you have. is it a 400w peak or what.
Old May 10, 2005 | 11:52 AM
flyromeo3's Avatar
flyromeo3
I second that.
He must have something else thats shorting the alternator.
Could also be a bad ground someplace.
I have a 10gauge power wire running from my battery to
all my audio/video components and even then its not power hungry.
Your problemo seems to be stemming from another source.
Old May 29, 2005 | 05:21 PM
si_zc_civic's Avatar
si_zc_civic
a cap is not "like a second battery" all a cap does is resist a change in current. it takes 5 RC time constants to charge up(near instananeous) and when the amp draws alot of current the cap discharges.
Old May 29, 2005 | 08:58 PM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
Audio guys, while you're on the subject, how much of a system does it take to stress out an alternator? Sorry to jump in here, but if I hooked up like a 200w or 300w peak 4-channel amp to my cabin speakers, would it shorten the life of the alternator or battery? No subs. Stock H23A Prelude.
Dan
Old May 29, 2005 | 09:06 PM
b00gers's Avatar
b00gers
Dan
A 200 - 300 watt PEAK amp is a very small amp. Probably 20-30 amps at max. Your battery and alternator will be fine.
