speaker questions
Old Aug 27, 2002 | 02:05 PM
naser61385's Avatar
naser61385
Default speaker questions
i got a 97 accord coupe, and recently i added a new kenwood head unit. however, when i turn the volume up to about 24 the speakers start skipping. is this because my head unit is too powerful for the spearkers? and if so, should i just get new 6 by 9's or just get an amp?
any advice would be greatly appreciated.
Old Aug 27, 2002 | 02:14 PM
b00gers's Avatar
b00gers
toss the stock speakers and invest in a good set.
Old Aug 27, 2002 | 07:11 PM
93acuraviga's Avatar
93acuraviga
Get some new 6X9's, you might be happy with the power the deck gives them and tehn if you're not you can always get an amp later
Old Aug 28, 2002 | 04:55 PM
97teg's Avatar
97teg
first what do you mean by skippping? second the head unit is probably only putting out maybe half what it says cleanly. They rate them with so much distortion its not even usable. If you really want good highs buy a nice small amp to power them. BIG DIFFERENCE!!!! Even with stock speakers.
Old Aug 29, 2002 | 09:13 PM
SiClone's Avatar
SiClone
X-Moder8er
skipping eh??? Sounds more like distortion. Replace the stock seakers and get an amp for them...
Old Aug 30, 2002 | 10:49 AM
ur31337's Avatar
ur31337
Colby
You should replace your speakers ASAP, I'm a HUGE boston acoustics fan. They're very high & bright, if you want something a bit bassier, go with JLs.
Old Aug 31, 2002 | 09:26 PM
93acuraviga
I agree with ur31337, if you do decide to get some new 6x9s, boston makes some great 3ways for under 150. Oh by the way, the problem probably isn't that the deck is giving the speakers too much power (most decks dont produce half the power/channel as they say they do). It's just that at higher volumes, the speakers probably get distorted b/c there's not enough power to push them at louder volumes... so an amp would be a solution also, but like i said, i would reccomend some new bostons first
Old Sep 1, 2002 | 07:35 AM
ur31337's Avatar
ur31337
Colby
Xtant, JL or Zapco amps would run the bostons well enough
Old Sep 4, 2002 | 05:57 PM
FrequencyAudio's Avatar
FrequencyAudio
Agreed. Stock speakers are just poor quality paper cones with bad foam surrounds. Typically when people install an aftermarket deck the next thing to go is the speakers, because the design on them is meant to be powered by the weak 10 watt per channel deck in there before. If you have any other questions or deceide on getting some 6X9's and an amp shoot me an e-mail for brands and prices! Good Luck
93CivicSiD16HB
92+ Civic/EL & Del Sol
17
Feb 4, 2006 09:35 PM
93CivicSiD16HB
18
Jan 27, 2006 09:00 AM
Kabooki
54
Apr 11, 2005 12:06 PM
