how much do these cost??
Old Aug 8, 2002 | 10:55 PM
steveng's Avatar
steveng
Default how much do these cost??
20 feet 4 guage wire, 4 guage in/8 guage out Dblock, one 150amp mega fuse, and RCA cable?
Old Aug 8, 2002 | 11:16 PM
b00gers's Avatar
b00gers
4 guage wire $.99/ft
d-block $10
150amp fuse $5-10
RCA $30+
that is a huge fuse btw. what amps are you planning to run, and how many amps can your alternator dish out?
Old Aug 8, 2002 | 11:25 PM
steveng's Avatar
steveng
i will be running two amps, one is 400x1 rms at 2ohm for the subs and the other is 4ohm stereo 70x2 rms. the alternator is stock, and i don't know how much amps it can put out
Old Aug 9, 2002 | 05:35 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
I would drop that fuse rating down to 60-80amps
Old Aug 9, 2002 | 06:27 AM
smokedogg's Avatar
smokedogg
when you said 150 amp fuse, i was expecting you to say at least 1000 watts total. i would definatly drop that fuse unless your planning on adding a huge amp later on.
Old Aug 9, 2002 | 06:28 AM
smokedogg's Avatar
smokedogg
in addition to my last post: im running a single amp at just about 1000 watts to my subs, with a fuse size of only 80 amps.
Old Aug 9, 2002 | 07:03 AM
b00gers's Avatar
b00gers
that fuse will be wayyy too thick. take a look at both amps, take a look at their onboard fuses, add them up. that should be the fuse size at the battery.
even if you are getting a bigger amp in the future, get the right fuse now, and replace it later.
Old Aug 9, 2002 | 07:05 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
150 amp fuse!! sheesh definately do what will said. look at the amp's fuse ratings
also 150 comes in a fuse? i would think u would need a circuit breaker for that size
Old Aug 9, 2002 | 07:13 AM
acuradriva's Avatar
acuradriva
ANL fuses go up to 300 c/b's only go up to 150A.
Old Aug 9, 2002 | 08:00 AM
steveng's Avatar
steveng
are u referring to the fuse for the power wire from the battery?
i read an article saying that 125amps fuse is recommended size for 4 guage wire, and since i will be running 4 guage wire upfront, isn't 80amps to small? I told the guy at the stereo shop that i wanted 125amp fuse, then he said, he would increase that to 150amps upfront and leave no fuse from the Dblock to amplifiers :dunno: . im confused.
