Whinning noise in speakers
Old Mar 27, 2004 | 07:07 PM
ohhonda98's Avatar
ohhonda98
Default Whinning noise in speakers
I finally got my new amp, an MTX404, it replaces my old SOUNDSTREAM 305. All I did was swap it out, now I hear a whinning noise. I thinik that it's alternator noise. My previous problem was not the "GHETTO WIRING" as someone put it. The Soundstream was nearly 10 years old, THAT"S RIGHT 10 years and still WAS going strong. My new question is how or what do i do to eleminate the alternator noise? Should I replace the RCA cables or check for a faulty ground from the head unit? Please advise....
THANKS IN ADVANCE
Old Mar 28, 2004 | 01:58 PM
john666's Avatar
john666
Drive it like u stole it.
well,, you can alwayz go to radioshack and buy a noise filter.. it connects to the back of your HU.. for me it works 80% of the time..
Old Mar 29, 2004 | 08:55 AM
SuperMario98Ex's Avatar
SuperMario98Ex
Try a different ground.
Old Mar 29, 2004 | 09:31 AM
strychnine's Avatar
strychnine
i am legend
when there is a whining noise a very good percent of the time it is a ground problem. do like you mentioned and check your hu ground. if it's not there try cleaning and retightening all of your grounds. since that doesn't cost anything i'd do it first then try new rcas, and make sure they're as far away from your power wire as possible. you shouldn't need a noise filter if you do those things since they're usually the problem.
Old Mar 29, 2004 | 10:14 AM
theguy387's Avatar
theguy387
if the noise gets louder as you are increasing speed then you might have to run the wires seperate.(wires from head unit that go to amp cannot be together) try running them on seperate sides of car. (one on driver the other passenger.) oh and try a different ground as well.
Old Mar 29, 2004 | 02:05 PM
ohhonda98's Avatar
ohhonda98
Thanks. I will try to do just that this weekend.
Old Mar 29, 2004 | 02:10 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
just need a better ground
Old Apr 2, 2004 | 10:21 AM
Spyfunkr's Avatar
Spyfunkr
Ever since I started running a ground wire from the head unit to the amps ground, I havent had this engine noise problem. If you ground your devices in different spots on the chassis, they can have a voltage potential. That can introduce the noise. As a practice, ground all your active components at the same spot(away from other wiring).
Good luck
Spy
HryHood
8
Apr 23, 2003 01:48 AM
Mike (CR) V
Accord
4
Mar 26, 2003 09:22 PM
moofoo
10
Jan 28, 2003 07:46 AM
bokchoyboi
92+ Civic/EL & Del Sol
3
Oct 21, 2002 08:18 PM
RacinSkittle
6
Sep 2, 2002 09:11 AM
