Cargo light wiring question...
Old Mar 16, 2004 | 06:33 PM
Spood's Avatar
Spood
Sucka
Default Cargo light wiring question...
I posted this in the 92+ Civic forum also, and I know this is not Audio/Security related, but I thought someone here might have an idea from whatever electronic work they've done.
My CX hatchback did not come stock with a cargo light in the back. I got a light from a friend and went to install it, and there's no wiring there! hnoes: So, the question is, what is the nearest constant 12v line that I can tap into? I don't care about it coming on when I open the hatch...I can just use the switch on the light. Any ideas? Thanks!
Old Mar 17, 2004 | 12:54 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
there most likely is no constant 12 volt source back there... you'll need to run a power wire from maybe the dome light, or under the dash.
If your car has a small idiot light when the hatch is open, you can wire the light to come on with the hatch opening... the switch on the latch sends a ground to that idiot light... so power the light from elsewhere, and wire the ground to the switch in the latch.
strychnine
3
Sep 17, 2003 10:30 AM
maskedSONY
92+ Civic/EL & Del Sol
2
Sep 3, 2003 09:30 PM
asaspade421
Mar 26, 2003 12:23 PM
