Building Accord Motor Tech Help Needed
Old Oct 5, 2003 | 07:45 PM
sphinx054's Avatar
sphinx054
Default Building Accord Motor Tech Help Needed
i just got a F22B2 block from a friend it came out of a 96 accord LX someone warped the deck and i asked my auto teacher and he said that it could be machined and be used. ok my problem- i dont want a dinky SOHC VTEC head and to my knowledge they didnt make a DOHC VTEC head on the accord except the accord euro-R which i think had the prelude H22A1 in it. I was lookin around the web to see what i could do and i came across a site that said that the head from a H22 could be put on my F22 block. i emailed the site and got no response. they claimed that they could put on there but i wanna know if it really can be done and what i need to do to do it. and i was also wondering what constitutes what ECU i use in my car it'll be an accord block with a prelude head. any thoughts? thanks for reading any help will be well appreciated.
Old Oct 5, 2003 | 09:06 PM
StickerMang's Avatar
StickerMang
It's not worth it, just do a full h22a swap and avoid issues.
Nate.
Old Oct 5, 2003 | 10:58 PM
polakatl's Avatar
polakatl
I did some reserach on the net about diff heads and all my sources said that u can't change heads with different engine serries. no H to F but B to B is ok... I'm sure u could still change the head but that would require custom everything.
Old Jan 18, 2004 | 12:46 AM
colblaha's Avatar
colblaha
I just got my '96 LX not too long ago, and you said that a B to B head swap is ok. So what are the differences between the f22b2 and f22b1 [other than VTEC]? What would i need to do to go from my b2 to b1? can i just swap heads? or are there electrical things i need to consider as well.
Thanks
Old Jan 18, 2004 | 12:56 AM
slpycd7's Avatar
slpycd7
H22 fo lyfe!
Thanks
i believe he ment H series motor to F series motor heads will not work. But B Series motor heads are swappable.
The F-series is swappable between themselves as long as you stay away from the SOHC Vtec motor. I think.....I'm open to corrections. Nightshade?
Old Jan 18, 2004 | 01:00 AM
colblaha's Avatar
colblaha
What would i do if i wanted to go from non-vtec f22b2 to a f22b1 vtec?
Old Jan 18, 2004 | 08:52 AM
03accordcoupe's Avatar
03accordcoupe
^New car...2003 BMW 330ci
I like my SOHC VTEC
