AEM Cam Gear and pulley kit question
Old Jul 3, 2003 | 07:23 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
Originally posted by MrChad
http://home.insightbb.com/~niedejb/
cam gear and pulleys will have results, see dyno tuning.
he also had a FPR and spent alot of time/money for 3hp on the dyno.
also, it's tough to tell,but he increased his top end by 3hp, but what did he sacrifice on the bottom. on a SOHC car all you are doing is moving the power band around. since he later went turbo the cam gear is good, but for your average person i wouldn't waste my time unless i wan also getting a apexi S-AFC or V-AFC tuned at the same time.
Old Jul 3, 2003 | 09:33 AM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Well, I don't think its a total waste. If you are having your t-belt reaplaced that would be a good time to install a cam-gear, in addition you could follow others tuning techniques as a guide. Running a new FPR isn't that expensive campared to the t-belt costs if you are paying to have it done. Once you have bought an I/H/E the cost of the two above items isn't that large. especially to gain 4-5hp in the daily powerband.
Old Jul 3, 2003 | 09:43 AM
AccordSleeper
If you are having your t-belt reaplaced that would be a good time to install a cam-gear, in addition you could follow others tuning techniques as a guide. .
been there, done that, i'm glad i was able to sell it for $40 after i did my swap. i bought one and had it installed when my timing belt was done. i went from running 16.5 in the 1/4 mile to 16.9-17.0 after messing with that stupid thing according to other people's suggestions. i set it back to zero.
Old Jul 4, 2003 | 09:16 AM
AcsRcool's Avatar
AcsRcool
Faster than your Geo
is that 16.5 with your h22?? i would have thought you would be faster than that. . .
Old Jul 7, 2003 | 03:44 AM
AccordSleeper
that was with the f22b1.
Old Jul 7, 2003 | 04:42 AM
pdr's Avatar
pdr
ridiculously good looking
165watt alternator can fix all that.
Old Jul 7, 2003 | 09:20 AM
MarylandHonda's Avatar
MarylandHonda
Originally posted by AccordSleeper
sorry i messed that up, the old style ones have allen wrench style bolts, those are the junk ones. you want the hex bolt style. the allen wrench style ones like on skunk2 can get stripped with repeated adjustments.
http://aempower.com/product_cam.asp
yeah ur right, ive tune mines only 3 times and the damn bolts r strippen, im like f it, ill just leave it set where i have it which is 3 advanced for low end. i wanna try 5-6 but im scared to mess with the bolts, scared i wont be able to tighten them back up. cause if u dont tighten them the cam gear will adjust to 10 retard, i kno, mines done it the other day.
i didnt use the right tool to tighten them.
