Sparco fuel door conversion.......
Old May 13, 2003 | 08:42 AM
decibel_dj's Avatar
decibel_dj
Originally posted by mizturyous
cutting thr frame around the original gas door is not as "work free" as you think. First of all the original door is plastic so it would have to be removed and a metalt plate welded into its place. then the hole cut and the frame reworked. Its just as easy and more of a custom job the way I did mione. But like you say "to each his own" I just wanted mine different than what may be what you call the "easy and simple route".
i got u on that one. hey i'm not into the setting trends but i feel u though. every1 that i've seen with the gas conversion just go ova the stock housing. so it has to be as simple as i think it is but hey being different is the whole point of tricking out cars
Old May 14, 2003 | 08:19 AM
OffDuty's Avatar
OffDuty
That location looks good until you are gassing it up & those last few drops pee all down the side of the car when you remove the nozzle as it always happens.. thats a lot of run-down surface with that up so high...
Old May 14, 2003 | 09:07 AM
decibel_dj's Avatar
decibel_dj
damn how u get those spots out? i have them on my ride now
Old May 14, 2003 | 09:11 AM
99accord's Avatar
99accord
www.poksquid.com
i like it.... looks clean.... i was thinking of doing something similar...
Old May 14, 2003 | 09:23 AM
mizturyous's Avatar
mizturyous
Terd Furgeson
I am not really worried about gas running down. Surely I can get those couple of drop that may run down off the car before they run all they way down. I dont think it will be an issue. I really dont have a problem with gas pee on my car now.
Old May 14, 2003 | 10:29 PM
Sham's Avatar
Sham
Ya treat the gas nozzle like your dick. When it's done pissing, give it a second to make sure its all out. Then pick it up, give it a couple shakes. I tap mine on the edge of the gas hole, to get any hanging gas piss. I then quickly pull away from my car, and put back into its correct spot.
Old May 14, 2003 | 10:52 PM
99accord's Avatar
99accord
www.poksquid.com
dad never taught you how to pee @ offduty?
Old May 15, 2003 | 05:09 AM
OffDuty's Avatar
OffDuty
:fawk: heh heh.. *I* dont have that problem, Im just sayin'!! I know the gas nozzle can be a PITA tho.
Old May 15, 2003 | 07:44 AM
DEaccord95's Avatar
DEaccord95
Living The Import Life
IMO i think it looks awesome. how much did that cost you?
Old May 15, 2003 | 01:27 PM
mizturyous's Avatar
mizturyous
Terd Furgeson
The Sparco locking door runs about 165.00 retail with the funnel...............not that cheap of an add on but I like it and I really wanted something different. When the car is finished it shouild really be sweet. The rings around the door handles are gone, keyholes gone, antenna gone,ring around tag area gone, keyhole in trunk gone, emblems gone,door moldings gone, just a little bit more touchuo work and its ready for paint.
