swapping auto for 5 speed
Old Nov 13, 2002 | 10:23 AM
92accord's Avatar
92accord
my teacher said it would probably be easy except for the wiring the pedals, and the hydraulics for the clutch.
Old Nov 13, 2002 | 10:27 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
With motor out the stuff under hood is simple. The pedals are a ***** manly cause they are hard to get to with the dash in place and wiring the reverse lights are your biggest headaches.
Old Nov 13, 2002 | 01:56 PM
ASIMO's Avatar
ASIMO
I am doing my conversion on my 90 Accord with the motor in place. no problem that I can see. I ws told that the WORST part is the pedals under the dash.
Good luck man and if you can post a "HOW TO" when your done.
Thanks
Old Nov 13, 2002 | 01:57 PM
ASIMO's Avatar
ASIMO
Originally posted by AccordSleeper
I would use a 92-96 lude shifter if you can though.
Why??? whats the difference?
Old Nov 13, 2002 | 05:22 PM
92accord's Avatar
92accord
i plan on posting some pictures and some how-to when i get the job finished...maybe help some other people out
Old Nov 14, 2002 | 02:26 AM
AccordSleeper
This is
Old Nov 14, 2002 | 06:40 AM
ASIMO's Avatar
ASIMO
This is
Still lost me. explain.
Old Nov 14, 2002 | 07:07 AM
92accord's Avatar
92accord
so the lude shifter is just shorter than the accord . they both go in the same. i went on to handa swap and i had a few people told me to sell it not even try it. But I wouldnt mind the knowledge. I do alot of mechanic work at school and at home but have never tried anything like this. I thought about just going with a stall converter but that route would probably cost about the same.
Old Nov 14, 2002 | 07:56 AM
AccordSleeper
The lude shifter is shorter, although throws aren't reduced it looks cooler and feels much nicer.
If you can do the work yourself then do the auto-manual. You have a donor car for parts, all you need now is the time, you seem to have the knowledge. Maybe on a real new car it would be worth it. Some of us have cars that are in really good shape that would be hard to find in a manual. There are not many 4 door 5sp EX Accords out there to begin with, now find one in good shape when they are 8-10 yrs old.
Old Nov 17, 2002 | 01:07 PM
90AccordEX4's Avatar
90AccordEX4
I just wanted to clear something up:
Someone on some other thread said that the auto-->manual swap was a total pain and really really hard or something. As someone who has done this swap (on my 1990 EX), I can say that it was not that bad at all, and A LOT easier than I thought it was going to be. The ONLY thing that is a pain is cutting and welding the tranny mount BRACKET to the chassis. Other than that, not too bad. You will NOT need a new ECU, reverse light wiring is a sinch, clutch pedal installation piece of cake. After all, both auto and manual cars are identical so all needed mounts/holes are already there. Oh, the Cruise Control took some tinkering to get to work again. Car runs like a champ now! Good Luck!!
