6th Gen throttle body spacer!?
In the good old days of V8's and carbs--spacers were placed under the carb. This in effect created a longer intake runner length --which force air to run faster in the the chamber b/c of length it has to travel in short.
This type of theory may also work well with a TB at increasing plenum effective runner length. Don't knock until the dyno shows it to be false.
Not that its worth 80bucks, traditional dometic V8 spacers were often made from High density plastic and cost around 20bucks???
No, use should buy it only because you want to buy it. I'd do more research to prove to yourself why you may or may not want this item. The boards are a good seed place for ideas or links but the ultimate purchase should be yours.
Originally posted by Cord 2oo1
So should i buy this thing and then get my car dynoed to show you guys the results?
-tom
-tom
Originally posted by accordv6vtec3r
