Car won't start??
Old Mar 25, 2008 | 08:03 PM
takume's Avatar
takume
Default Car won't start??
Hi, I have a 1994 accord lx with 145k. Today after I get off from class and ready to go home. I could not start my car. All I can hear is a ticking noise from the distributor area. So am I having a bad distributor causing the issue? If so, can I just go to auto zone or dealership for replacement part. Thanks.
Old Mar 25, 2008 | 09:52 PM
nspec_Cd5's Avatar
nspec_Cd5
*from what u described*, ur battery is dead. u just need to jump it.
if that doesnt work, then its relaterd to ur starter
Old Mar 26, 2008 | 06:11 AM
takume's Avatar
takume
I can turn my car to started position (II) but no spark at ignited position (III). The audio and every electric thing on my car work. So can I eliminate the battery problem?
Old Mar 26, 2008 | 07:06 AM
TL-Super's Avatar
TL-Super
Have you tried boosting it?
If your battery is on it's way out, it may have enough juice to fire up interior stuff but not enough cranking amps. Depending on type of battery they can last only two years or as long as 5 -7 years. In my experience.
Old Mar 26, 2008 | 11:03 AM
Tedmond's Avatar
Tedmond
you might want to search the forum for "MAIN RELAY" this is some problems on most accords and honda's in general.
Old Mar 26, 2008 | 01:14 PM
takume's Avatar
takume
I will do that. Thanks for the head up. Well, maybe I did not describe it very well. I mean when I crank my car, I hear that very loud and noisy sound ( like something try to rotate inside the distributor but blocked ) from the distributor area. I am looking for a way to test where is the problem probably on tommorow. So really want to get some helps. Thanks in advanced.
Old Mar 26, 2008 | 01:24 PM
takume's Avatar
takume
The sounds is like buzz noise ...like a ZZZZ shock noise from the distributor areas when I crank the car. My friend told me it could be the main relay?? I don't know.
Old Mar 26, 2008 | 07:09 PM
tommytomtom17's Avatar
tommytomtom17
Honda Driver
Sounds like a starter to me, if it was your main relay it would fail to send a signal to your fuel pump and you wouldnt hear it come on when you turn your key on, It would still crank. If you think its your relay just take it out and resauder the contacts. Is it an automatic?
Old Mar 27, 2008 | 11:30 AM
Joshatdot's Avatar
Joshatdot
got a digicam with movie mode? record movie and host it on YT so we all can hear it.
Old Mar 27, 2008 | 05:33 PM
takume's Avatar
takume
thanks for all input so far. I have figured that I have both a bad battery plus a bad starter. I have already put a new battery in it. My question is how to remove the starter. I search the forum, and people said that I only have to remove two 14mm bolts and pull it out? Any special tips or tools? Because I see many things in the engine bay which block the starter way out
