87 Accord door panel removal
Old Mar 8, 2008 | 11:32 AM
KRC116's Avatar
KRC116
Default 87 Accord door panel removal
I am trying to put a new driver's door window in after the car was broken into. I have taken all screws out and the panel is free from door body. I can't seem to get it loose from the top trim piece that the window seal/squeegee is attached to. Any help on how to get the door panel off without doing any damage would be appreciated.
Thanks
KRC116
Old Mar 8, 2008 | 05:26 PM
Tedmond's Avatar
Tedmond
you will remove the lower portion, the seal around the window to the panel, lift it up and towards you. make sure you removed the door handle.
