I Need Help On My H22 Swap
Old Jun 13, 2007 | 10:17 AM
HondAccorlude18's Avatar
HondAccorlude18
the thing is i dont have triptronic i was told i can buy the Automatic Transmission Control Module (TCM) but i need some info on what part number it would be cause i found some on ebay but im afraid if i buy the wrong one im stuck with the TCM for nothing and ending up buying another one can anyone or you please help me so i can get this car on the road already....another question theres no JDM or any car meets in Miami Or Anywhere in Florida
Old Jun 13, 2007 | 11:57 AM
stereo's Avatar
stereo
like I said the only automatic H22a here in the US is the tiptronics (sportshift) transmission and they use a diffrent TCM then your F22 trans so in order to use the 97+ prelude TCM you need the ECU,TCMand trans from a 97+ prelude + deal with the immobilizer. or to just have VTEC use a 96 accord EX auto ecu or no VTEC put your Dx ecu in to drive the car.
Old Jun 13, 2007 | 12:01 PM
stereo's Avatar
stereo
like I said the only automatic H22a here in the US is the tiptronics (sportshift) transmission and they use a diffrent TCM then your F22 trans so in order to use the 97+ prelude TCM you need the ECU,TCMand trans from a 97+ prelude + deal with the immobilizer. or to just have VTEC use a 96 accord EX auto ecu or no VTEC put your Dx ecu in to drive the car as the TCM would have to be wired in. i'm doing the same swap but using a H22a4 with the sportshift auto it's the only way to do the job without the headeaches .
Old Jun 13, 2007 | 05:29 PM
HondAccorlude18
i have a 95 H22a automatic with ecu but no TCM
Old Jun 13, 2007 | 11:11 PM
stereo's Avatar
stereo
so you converted your car to OBD1 ? if so try a TCM from a 94-95 accord.
Old Jun 14, 2007 | 02:23 AM
nspec_Cd5's Avatar
nspec_Cd5
The FIRST problem is in you shifter. its hard as hell to take it out of park. That is common problem in CBs, but rare in CDs. swap that out w/ a good one, but if you wanna go more into it and try fixing it'll take a s*** load of time. (let me know if you wanna do that)
and for the second problem. i'm not so sure, does it work in all 1st through 3rd gears? i mean can you shift it in to 1, 2, or D3 and then drive? or only in 1st?
if it only runs in first, then try this, cruise at 20 and shift it into "2" w/ out taking your foot off the gas. and if it shifts in to 2nd then trying shifting it in to D3 @ about 30+ mph. and if that works then shift it into D4 at higher speed like at 40mph.
let me know what happens.
Old Jun 14, 2007 | 02:27 AM
nspec_Cd5's Avatar
nspec_Cd5
leave the first problem for later and work on the second one.
Old Jun 14, 2007 | 09:31 AM
stereo's Avatar
stereo
the problem is he swapped a H22a motor with a F22 auto trans into a 96 OBD2 car that has a PCM and using a JDM ECU (likely OBD1) with no TCM to control the trans. thus not getting out of park or shifting since theres no computer for the trans. as it was built into the F22 computer.
