flashing oil light
Old May 16, 2007 | 03:51 PM
meangreen90's Avatar
meangreen90
Default flashing oil light
'90 honda accord ex. Drove it almost one mile the other day across campus and the oil light started flashing at me. I had just added oil the day before to top it off and it was only a half quart low. Never heard of honda oil pumps wearing out. Got both new timing/balance belts. Bad sensor? Loose sensor wire? Haven't had time to get it on the lift.
Old May 17, 2007 | 07:19 PM
meangreen90
Is this so unheard of or what? Still haven't had time to look at it but i was hoping to have something to go on from you guys before I looked into it.
Old May 17, 2007 | 08:18 PM
JimBlake's Avatar
JimBlake
It's not real rare for the oil pressure switch to go bad. But if you don't have a pressure gauge to verify that, you have to take your chances about assuming the actual oil pressure is OK.
Bad oil pump isn't the only reason for pressure to be low. Sometimes the oil pickup screen in the pan gets obstructed.
Old May 18, 2007 | 12:23 PM
92civiclx's Avatar
92civiclx
On my wifes 92 lx the oil light flashes when its low on oil. But that doesn't happen often.
Old May 18, 2007 | 01:38 PM
meangreen90
I've had the oil pan off 2 years ago for a new gasket and everything was spotless. Unless some gasket somehwere let loose and is right over the pickup, I should be ok.
Old May 18, 2007 | 02:14 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Do not drive the car and have it looked at
/thread
Old May 19, 2007 | 04:29 AM
meangreen90
well thats kind of a no brainer...I'm ASE certified so i can do the same thing a honda shop can do but a hock of alot cheaper. I'm coming to you guys for any info available. Like I said, sensors prone to going out? Pumps prone to going out? I'm gonna hook up a mech gauge today and see what I'm getting or not getting...we'll see.
Old May 24, 2007 | 12:12 PM
nspec_Cd5's Avatar
nspec_Cd5
do another oil change. or change ur dip stick. some how, my dip stick started slipping oil off of it and gave me a wrong reading every single time. I changed it and was surprised.
