Power steering pump problem
Old Feb 1, 2007 | 03:01 PM
davewillner's Avatar
davewillner
Default Power steering pump problem
I just replaced my alternator after 210K miles on my "01 V6...needed to move the power steering resevoir to access the bolts. I must have turned it upside down or moved it out of the way somehow that affected the pump. The pump seems to be working fine, but makes a lot of noise, especially when going lock to lock, and the fluid is bubbling up and spilling out the filler cap. Is there a check valve or something in the hose or something I could of wacked out of place? I drove it a lot today and still have the noise and seems like a whole lot of air is in the lines. Any ideas how to remedy? Appreciate the help
Dave
Old Feb 1, 2007 | 04:36 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Just rip it out. Power steering is for girls
Old Feb 1, 2007 | 10:47 PM
wedley2's Avatar
wedley2
bboy Wesley West
try re-bleeding the powersteering.
open cap and go from side to side without stopping or hitting the end of the turn.
Old Feb 2, 2007 | 08:10 AM
sibiryk's Avatar
sibiryk
Did you loose any steering fluid from resevoir?
Check fluid level.
I had a bad pump on my civic and it did cause many bubles in a resevoir that made fluid to come out from the top. Only pump replacement fix that problem.
Old Feb 2, 2007 | 08:43 AM
davewillner
I've been "bleeding" with the cap off, lock to lock, several times, no luck. Also drive it about 150 miles this week, no help. I have not lost any fluid, its right up to the mark. This started happening right after I moved it from the bracket for room to get at the alternator....I've never had a problem with it, never been low....Could it just be a coincidence it and the alternator died at the exact same time?
Old Feb 2, 2007 | 08:44 AM
davewillner
How easy is it to replace the pump on an 01 V6 Accord...is it straightforward? Any surprises? Appreciate the help
Dave
Old Feb 2, 2007 | 09:14 AM
wedley2's Avatar
wedley2
bboy Wesley West
well, if you can replace the alternator, im sure you can replace the pump
just a highpower line and the return, kinda messy but very doable.
Old Feb 2, 2007 | 12:05 PM
sibiryk's Avatar
sibiryk
Check hoses too before pump replacement, you could damage or moved one so it would suck air in the system.
Old Feb 2, 2007 | 12:34 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Hmmm, strange....... all I did was disconnect the tube at the ps pump and that gave me enough room to change my alternator on my V6, needed to move the front cooling fans though.
