97 Accord tranmission problem. Please help!!
Old Jan 30, 2007 | 06:07 AM
john mccormick's Avatar
john mccormick
Default 97 Accord tranmission problem. Please help!!
97 honda accord transmission does not work. I have checked the linkage at tghe gear shifter and the cable to the transmission and it moves when it is moved into gear. I have checked the fluid. My daughter told me that she had some slippage problems, but when I test drove it the other day it seemed fine. Now when I put it into gear it does not go in forward or reverse. Once it is warmed up it does seem to pull a little bit in reverse.
any advice and comments are much appreciated in advance
Old Jan 30, 2007 | 07:11 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Can you explain what you're trying to say here? This is automatic transmission correct?
Old Jan 30, 2007 | 12:13 PM
john mccormick
yes it's automatic,started take longer to grab after putting in drive warm up it did ok till now,
Old Jan 30, 2007 | 07:30 PM
strykernyc's Avatar
strykernyc
need new tranny!
Old Jan 31, 2007 | 11:14 AM
flyromeo3's Avatar
flyromeo3
Originally Posted by strykernyc
need new tranny!
for that series you could start with checking the solenoids.
Dont ask where they are cause I have no clue. Im just aware those generations had a problem with tranny. solenoids.
