strut bars ? and window problem
Old Aug 31, 2006 | 08:14 AM
bullet4011's Avatar
bullet4011
Default strut bars ? and window problem
well my front passenger window goes up real slow when i need to put it up i have to play with it can someone help me thank you?? How hard is it to install upper strut bars and lower bar and the c-pillar ( the one that goes behind the seatis it worth it putting all of them. And what about the one in the trunk.
Old Aug 31, 2006 | 11:14 AM
rwong410's Avatar
rwong410
Upper strut bars are extremely easy to install. Just remove the bolts, add on the strut bar and put the bolts back on
Old Sep 6, 2006 | 01:04 PM
breaker1's Avatar
breaker1
Yeah, as the previous poster mentioned, the strut bar is extremely easy to install. I think it took all of 10 minutes to install mine.
I have the same problem with my drivers side window in my car (96 accord ex) and I understand that it's a common problem. I have been told (two things) that it's the relay and that it's the actuator (sp?). I don't imagine that it's a super easy thing to replace given that it's inside of the door, but it's also not a transmission rebuild.
Old Sep 7, 2006 | 10:18 AM
bubbrubb's Avatar
bubbrubb
I have the upper strut bar and i think it did absolutely nothing for performance for my car (00 accord coupe)
Old Sep 7, 2006 | 10:21 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
^^What bar do you have?? I noticed a pronounced difference in handling with my Eibach ProBar.
Old Sep 7, 2006 | 01:00 PM
Big AL's Avatar
Big AL
Swollen Member
I didn't notice any difference with my strut bar install either and I have the neuspeed 1 piece bar. I noticed a huge difference with my new rear sway bar. Maybe I would've noticed a difference if I would've installed the strut bar first and then the rear sway bar? :dunno:
Old Sep 7, 2006 | 01:22 PM
totalimmortal
MalleusMaleficarum
I got my front upper first, then the TL-S Rear. I dunno if order would have made a difference either.
Old Sep 7, 2006 | 03:41 PM
bubbrubb's Avatar
bubbrubb
i have the eibach one on top. absolutely the exact same handling. I might have my engine builder fab me one up for the bottom in front and back.
Old Sep 9, 2006 | 12:29 PM
jschmid's Avatar
jschmid
On our cars I think that the handling threshold where you'll feel a difference in a upper front strut bar is pretty high. You have to be pushing the car somewhat near it's limits to feel a difference. But when you can buy a TL-S bar for $40-50, why not, so I have one on my 6th gen.
You'll feel more of a difference in handling by adding a thicker rear sway bar.
