Free flow air filter
Old Jul 29, 2006 | 12:28 PM
JimD's Avatar
JimD
Default Free flow air filter
I recently read that dropping in a free flow air filter will increase performance. True? Downsides? Thanks
Old Jul 30, 2006 | 02:04 AM
dimaj's Avatar
dimaj
2005 Coupe Ex 6MT
I hear the same
The upsides (at least in my opinion) better performance (maybe) and better sound of the car
Downsides - If you are going to go with something self made or something cheap (like on eBay) your car will not pass the smog check. I think they require some sort of a stamp on the intake in order to pass the check... The work around is to keep your original intake and right before taking your car for a smog check, swap them out. I know it is a bit tideous, but it works
Good luck!
dimaj
Old Jul 30, 2006 | 07:10 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
The highest flowing filter I've ever seen was the Blitz Stainless Mesh filters. Although, they only filter out particles the size of Montana.
Old Jul 30, 2006 | 07:32 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
K&N Oem Replacement ftw :yes:
Old Jul 30, 2006 | 09:57 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
^^werd.... better gas mileage too
Old Jul 30, 2006 | 07:12 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I removed the resonator chamber from my OEM air box, then I installed a K&N oem replacement filter.
Why would anyone do this.
Well I hade an AEM CAI and an AEM short ram. Both used 2.5" tubing, the OEM intake tube is 2.5" too.
I was able to fit the conical AEM filter on the end of my OEM intake tube, I found that seat of the pants dyno registered this as the same as my AEM intake complete.
I also had issue with my AEM intakes wearing out, well I may not be typical; but after 6.5 years of use my AEM intake started to wear out rubber bushings, and I split a bypass valve in half.
Removing the resonator from the OEM air box effectively means you get to suck colder air (unrestricted) from below the fender well. 2nd the OEM intake tube is no worse then the AEM 2.5" interms of flow. If you do the math the surface area of the OEM intake is not much better then the AEM conical filter.
So with the OEM resonator removed we get cold air from the fender well like the AEM or other 3rd party intake. We get the same size intake tubing, and we get a free flowing filter with the aftermarket drop in style. Plus we get OEM reliability in terms of build quality over 3rd party. And as a bonus removing the resonator makes the car sound just like an aftermarket intake.
Makes me wonder why everyones spending hundreds on 3rd party intakes?
Old Jul 31, 2006 | 05:46 AM
totalimmortal
MalleusMaleficarum
They're pretty:yum:
