Wheel & Tire sizes?
I tried a new thread and didnt get any response.
I have a set of 17x8 et38 Momo M1 chromes I want to put on my 03 accord coupe. I wanted to put a wider tire on than stock and still be able to drop the car an inch or so. The 17 stock size is 215/50/17.
I think the Acura RL's use 235/45/17's anybody have experience?
Reading Wheel Sizes: per discountTiredirect.com
Example Size: 15x7 4-100 40S
15 - Rim diameter in inches.
7 - Width of rim in inches.
4-100 - Bolt Pattern.
4 - Number of lug holes in wheel.
100 - Distance between lug holes (in millimeters).
Some wheels have multiple bolt patterns.
15x7 4-100/108
This wheel fits cars with both 4-100 bolt patterns and 4-108 bolt patterns.
40S - Offset and finish
40 - Measures in millimeters how far back or forward the mounting surface (face) is from the center of the wheel.
S - Silver Finish.
15x7 4-100/108
S - Silver Finish.
The goal is to keep the height close to stock for speedo reasons and keep the width within the wells or really close. I bought the M1 rims because I have seen them on lexis and MB cars and they look classy. My coupe is stock black and I dont want a tuner or race look.
So you think a 38 offset rim will stick out to far. The stock rims sit back a little and they are around a 45 offset or so?
one of the 17 tire option sizes given for the 03 coupe is 225/50/17 so one up is 235/45/17. I was hoping that someone has done something similar
Factory is +55mm, +38mm will stick out bad. I have +42mm and they are damn near even with my fenders. 225mm's wide will be plenty for the average person.
Here's how you find out how off you'll be.
http://www.paspeedo.com/calculator.htm
I have checked the dims and the speeds are fine. I did a search on Discount tire and most of the options for a 16" wheel is around a 38 offset.
If I dont like the way the rims look I can get rid of them. I didnt want to have to buy and mount tires if they wouldnt fit the car. It's hard to believe that no one has tested the 235/45/17's on a 7gen and posted it.
I think I'll stick to the 225/50/17 to be safe though unless some post more info.
site on 16" rims for an 03 accord
http://www.discounttiredirect.com/di...vid=007569&bp=
h:
