Help me with miss please
Old Jun 5, 2006 | 06:28 PM
hooptie's Avatar
hooptie
Default Help me with miss please (FIXED!!!)
(FIXED!!!) I have a 89 honda accord that has a miss on #2 cyl. I took the plug wire off of it while it was running and it didn't change any but it did when i took the other 3 off, 1 at a time. I put a new plug in that cyl. and still no change. It has new wires so I switched wires with another cyl. and still no change and it is getting fire to all plugs. What next or does anyone know what it might be. This is my first post so please bear with me, and take it easy on the newb'.
Old Jun 5, 2006 | 06:29 PM
hooptie's Avatar
hooptie
I switched fuel injectors and still no change. Any suggestions?
Old Jun 5, 2006 | 06:31 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
There could be lots of causes for a misfire. Remember that the cylinder has to get enough air, enough fuel, and the timing has to be right. So backtrack through those and see what the problem might be.
Old Jun 5, 2006 | 06:53 PM
hooptie's Avatar
hooptie
Thanks. I do something different everyday. I have had it for about a week. I got it to drive to work and back. Once I am going above about 1500 rpm it drives real good with no miss. It is just when it is ideling.
Old Jun 5, 2006 | 07:14 PM
98CoupeV6's Avatar
98CoupeV6
That sounds like it could be a problem with the throttle body components (maybe just simply cleaning the butterfly valve) or the EGR port, if your car has them.
Old Jun 5, 2006 | 08:16 PM
hooptie's Avatar
hooptie
I will try that tomorrow. Thanks.
Old Jun 6, 2006 | 06:59 PM
hooptie's Avatar
hooptie
I am leaning towards a bent or burnt valve.
Old Jun 6, 2006 | 07:05 PM
98CoupeV6's Avatar
98CoupeV6
Hm. Do a compression test?
Old Jun 6, 2006 | 07:38 PM
hooptie's Avatar
hooptie
Yeah that is next. I am leaning towards a bent or burnt valve.
Old Jun 11, 2006 | 04:43 PM
hooptie's Avatar
hooptie
I adjusted the valves today and the miss is gone!!! #3 cylinder was so off that you could practically put a penny in between the valves. This site is so helpful and I appreciate all of the help.
