Help me with miss please
Old Jun 4, 2006 | 06:31 PM
hooptie's Avatar
hooptie
Default (FIXED!!!) Help me with miss please
(FIXED!!!) I have a 89 honda accord that has a miss on #2 cyl. I took the plug wire off of it while it was running and it didn't change any but it did when i took the other 3 off, 1 at a time. I put a new plug in that cyl. and still no change. It has new wires so I switched wires with another cyl. and still no change and it is getting fire to all plugs. What next or does anyone know what it might be. This is my first post so please bear with me, and take it easy on the newb'.
Old Jun 5, 2006 | 06:18 PM
hooptie's Avatar
hooptie
I switched the fuel injector with another cyl. and still no change. Any suggestions?
Old Jun 5, 2006 | 10:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Run a compression test on that cylinder. It sounds like it could be lacking compression for ignition if the electrical and fuel system is ruled out.
Did it just start doing this out of the blue?
Old Jun 6, 2006 | 03:39 AM
hooptie's Avatar
hooptie
Thanks man and no I bought it this way.
Old Jun 6, 2006 | 12:30 PM
Provocateur
On permanent hiatus
Ok. It could be something causing the cylinder to have insufficient compression such as a stuck/bent valve, deep scoring on the cylinder walls, blown out rings, headgasket, broken ringlands/pistons, etc.
Old Jun 6, 2006 | 01:47 PM
hooptie's Avatar
hooptie
That's kinda what I was thinking. Thanks for the info and I will let you know what it is when I find out.
Old Jun 11, 2006 | 04:46 PM
hooptie's Avatar
hooptie
I adjusted the valves today and the miss is gone!!! #3 cylinder was so off that you could practically put a penny in between the valves. This site is so helpful and I appreciate all of the help.
Old Jun 11, 2006 | 11:02 PM
Provocateur
On permanent hiatus
Good to hear.
