startup problems
Old Nov 13, 2005 | 11:45 AM
sina518's Avatar
sina518
2draccord
Default startup problems
when i start my car in the mornings and its cold i hear a winding noise for 2 seconds and it goes a way any one know what it is. also their is something that ticks and when the motor warms up it goes away i think i need a valve adjustment but im not sure someone please help me. this is on a 2000 accord 4cyl
Old Nov 13, 2005 | 12:42 PM
bighavic's Avatar
bighavic
The winding noise could be the starter getting stuck in flywheel when it starts. Try lubing the starter gear. The ticking noise usally happens when the motor is cold and the oil has not yet reached the valves. For that i suggest to check the oil and possibly change it with a sytheic type.
Old Nov 13, 2005 | 02:23 PM
sina518's Avatar
sina518
2draccord
i always use mobile fully synthetic 10w-40 and i check it on a weekly bases
Old Nov 13, 2005 | 04:46 PM
bighavic's Avatar
bighavic
I thought Accords recommend 5W-30. The tapping will go away when its warm. Find a lube that sticks to the valves I don't remember one but I know they make one.
Old Nov 13, 2005 | 05:42 PM
sina518's Avatar
sina518
2draccord
ill try that but what if i had my tech adjust the valves to make sure their tight
Old Nov 13, 2005 | 10:40 PM
wedley2's Avatar
wedley2
bboy Wesley West
what if what?
Old Nov 14, 2005 | 11:35 AM
bighavic's Avatar
bighavic
If you like but adjusting the vavles can't be made tight because adjusting valves is for clearance between the head and the pistons, an up and down motion. Then again it might only take the ticking noise away for a short time. It has to do with the oil!! Your call It will go away with good oil change/cycle and a good filter. Did you look into any additives?
Old Nov 14, 2005 | 04:03 PM
sina518's Avatar
sina518
2draccord
no i have not looked into any additives my cousins is a master tech and he tells me there all garbage
Old Nov 15, 2005 | 05:35 AM
JimBlake's Avatar
JimBlake
Adjusting valves isn't exactly a bad idea, but probably unrelated to the noise. If your cousin's a master tech, he won't screw up your engine by making the valve clearances too small. The worst thing that can happen is he'll measure them & find they're just fine. Then he'll tease you for wasting his time or your money.
Have him listen to the noise. A good tech can easily tell the difference between the sound of valves (out-of-adjustment) vs. a starter that isn't disengaging. We can't actually hear it from here.
BTW; adjusting valve clearance has nothing to do with clearance between the piston & the head! (?)
Old Nov 15, 2005 | 03:55 PM
sina518's Avatar
sina518
2draccord
yeah im gonna have him listen to it everytime i ask him to he says he is busy. thanks man
