94 Accord help!
Old Oct 30, 2005 | 03:54 PM
OHS's Avatar
OHS
Banned
Okay did this problem develop suddenly or come over time. Am I to understand you serviced this car with synthetic oil and the previous owner did not. If so did this problem start after the switch?
Old Oct 30, 2005 | 04:02 PM
JiggaD369's Avatar
JiggaD369
pretty much it started after the switch. it has been going on for about 6-8 months.it looks like the i have to narrow odwn to replacing head gasket, timing belt, water pump, oil pan gasket, and do a valve adjustment to get it running normal. am i goign in the right direction or if not can you suggest other thingsi need to look over?
Old Oct 30, 2005 | 04:16 PM
OHS's Avatar
OHS
Banned
What has probably happened is the thermostockle valve has probably blocked the kineuter and it's gonna shell some shit out
Old Oct 30, 2005 | 04:31 PM
JiggaD369's Avatar
JiggaD369
so i have to inspect the oil pump tube and go back to regular oil. any other things i should look at except the pump/belt?
Old Oct 30, 2005 | 04:40 PM
OHS's Avatar
OHS
Banned
No just the thermostockle valve
Old Oct 30, 2005 | 04:59 PM
JiggaD369's Avatar
JiggaD369
so i should just save my money and look at newer engines. i dont know what oil was put in the engine before i switched but when i got the car i went to Jiffylube but after that i switched to synthetic. so should i just put regular mobill in there? and should i clean the pan ad the screen with acetone?
Old Oct 30, 2005 | 05:36 PM
Thooks's Avatar
Thooks
President-2008
Sounds like you've got a multitude of problems.
I would suggest either an engine swap or a tear down and rebuild. You might look at doing it yourself with the help of a mechanic on the side. Since you work at a parts store, you should know who you'd like to help you.
Another option would be to look at a new engine, maybe from Jasper or something else with a REAL warranty.
Sounds like you've got problems in the head and short block.
Old Oct 30, 2005 | 06:31 PM
OHS's Avatar
OHS
Banned
I clean all of my oil pans and pick-ups with a specific cleaner. Since I use this cleaner in the "Extreme Detail for Extreme Profits" tm instructional video and the moderators dont want to hear about my idea , I guess I just cant tell you now can I?????
Old Nov 5, 2005 | 07:13 PM
JiggaD369's Avatar
JiggaD369
hey OHS, what's your email address? cant send you an email through here so please provide me with it please. thanx.
