car problems
Old Oct 18, 2005 | 05:51 PM
ajth87's Avatar
ajth87
Default car problems
I am having this problem with my 1991 Honda Accord. First problem is that when I tried to start it today and yesterday it wouldnt start. It wouldn't work with a jump because it doesnt need a jump. The battery is good it has a half tank of gas. It sounds like it wants to start but just wont. And the other problem is that when it is running in park, it just revs by itself, the idle is high, It will go high then back down and repeat that til I put it in gear. When I put it in gear the car just goes it doesnt even need any gas to go. And when i am about to stop it is hard because it feels like it doesnt want to and when I am driving and I let off the gas it just keeps going before it starts to slow down and then it is still hard to slow down. can someone help me please.
Old Oct 18, 2005 | 06:17 PM
OHS's Avatar
OHS
Banned
Default You said please, I hope this helps
The problem you are describing sounds like you may have a loose nut behind the wheel.
Old Oct 18, 2005 | 10:33 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by OHS
The problem you are describing sounds like you may have a vacuum leak somewhere. Listen for a "hissing" noise while running. The unstable idle is most likely caused by that or the the Idle Air Controller, located near the center of the intake plenum (top intake), below the PCV hose. It has an electrical plug attached to it. Disconnect the plug when the idle fluctuation begins. If it stops fluctuating, this IAC can be removed, the screen cleaned and reinstalled usually with good success. Use new "O" rings, clean the "O" ring grooves and the plenum where it mounts. "O" rings are available from Honda only as far as I know. A fast idle valve failure (to the right of the IAC) could also cause consistent fast idle. This valve is kind of like a "controlled vacuum leak" and has a thermostatic element inside kinda like a thermostat. As the engine warms up, the fast idle valve is supposed to close and the car idles at it's normal speed. If this valve fails to close it will idle fast, and have some of the same characteristics of a vacuum leak. It's also a good idea to check the basics too ie plugs, air & fuel filter, ignition timing. There aren't too many things that can cause the problem you described so if you're mechanically inclined you can probably diy.
Good luck, work safely
Ozarks Honda Specialist is committed to being the best
Good to see a Honda tech on here
This man is correct in diagnosing your second problem. In fact this should be FAQ'd because that's one of the best explanations I've ever seen.
In regards to your first problem, it's probably your PGM-FI Main Fuel Relay. Try a search, I've posted where it is and how to test whether or not it works before. It's a very common problem.
Old Oct 19, 2005 | 01:11 PM
OHS's Avatar
OHS
Banned
Default Thanks!
98 Coupe V6,
I'd rather choke on hiv contaminated razors than be in FAQ here
