check engine light code: 70?
Old Oct 19, 2005 | 10:33 AM
flyromeo3's Avatar
flyromeo3
Originally Posted by 98CoupeV6
Pep boys won't read the tranny code, only the CEL, and are you aware you are fully capable of gathering the codes yourself?
well with the paper clip method. the D4 light flashed 4 times.
yes but i went to confirm that they got the same codes on the reader that I got using the paper clip
P0700
P0740
those are what I got.
they didnt read the actual tranny code ( by hooking up the reader to the TCU )
I called American Honda and they basically said nothing can be done. I have the extended warranty for my 02 which ended at 75k miles.
Right now I have 94,xxxk miles and am pissed. They told me that the warranty was extended for the 98-01 accords up to 100k miles.
So i told her what are the odds that the 02's are fixed. Can you gurantee that the 02 models are exempt from this tranny failure.
I dont beat on my car if anything I drive alot. I would say about 92k miles of this is nothing but highway miles since I've driven this car from coast to coast. Highway miles wont wear the tranny also.
I dont know how else to proceed with this. I dont want to go to Honda and pay xxxxxxxxxxxxx dollars for this. Im a bit dissatisfied with how the agent addressed my problem.
Basically, there is nothing we can do. Goodbye.
I replace my tranny fluid every 15-20 k miles just to avoid this potential problem. After I bought the car thats when i heard about the notorious tranny failures etc.
Tranny is shifting very weird upshift and downshift from 1st to 2nd and 2nd to 1st when coming to a stop.
Im getting to the point where this will be my last Honda.
Old Oct 19, 2005 | 10:56 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Dude you're not a noob...this topic has been covered tons of times. Do a search for the DTCs, they're all posted, you probably wont have a problem getting either a free tranny or a hell of a deal on a tranny from Honda.
Old Oct 19, 2005 | 12:01 PM
flyromeo3's Avatar
flyromeo3
i have been searching and got some info mainly from the VP6.net site.
Im just concerned about this 02 warranty thing they are telling me.
I guess all i ahve to do is bitch, bitch, bitch to get it honored.
Old Oct 19, 2005 | 12:03 PM
98CoupeV6's Avatar
98CoupeV6
Well sweet, but all of the info has been posted here as well.
Old Oct 19, 2005 | 01:22 PM
flyromeo3's Avatar
flyromeo3
this is the only thread were the person is actually experiencing the same symptoms. I've P'm'd blkaccd so im waiting for a response.
Old Oct 19, 2005 | 01:55 PM
flyromeo3's Avatar
flyromeo3
update: 10/19/05 - I disconnected the battery for a few minutes to see if it clears the CEL.
Upon reconnecting the battery the CEL is no longer on. I drove the car around the block without any problems. The symptom i experienced yesterday no longer was present. Lets see what happens when i get onto the freeway.
Old Oct 19, 2005 | 07:56 PM
stereo's Avatar
stereo
check the trans fluid to see if it smells burn't from what I hear (cannot confirm) is that the torque converter goes bad and throws crap into the trans ,clogging the internal filter screen and burning up the clutches as we had a few of the 6th gens that would drive fine when first driven but after some miles down the road would not shift or slip .
Old Oct 19, 2005 | 08:13 PM
98CoupeV6's Avatar
98CoupeV6
https://www.honda-acura.net/forums/s...ighlight=P0740
Everything you could possibly need to troubleshoot it is listed in those two threads. P0700 is a generic trouble code not pointing to anything specific. Did you not see the info in those 2 threads or do you not understand the procedure? It's kind of tricky to test yourself but it's doable.
Old Oct 20, 2005 | 06:17 AM
flyromeo3's Avatar
flyromeo3
i tired signing up to alldata but it says that Honda America doesnt want their info published there..etc.
where can I locate these soleniods? A & B.
If anyone has a diagram or picture it would help a lot.
Old Oct 20, 2005 | 06:25 AM
98CoupeV6's Avatar
98CoupeV6
I'm well past the point of helping you out. If someone else wants to try they can :doh:
