Rear Brakes
Old Jul 27, 2005 | 09:14 PM
AccordVT's Avatar
AccordVT
Ian
Think of it as a wheel and low pro tire........Tire is where the pad hits wheel is where it does not... I need more sidewall (More pad touching)
Old Jul 27, 2005 | 10:43 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
so you have a gap between where the top and bottom of the pad touch the rotor? or just the top of the pad touches and the bottom does not?
Old Jul 28, 2005 | 07:17 AM
AccordVT's Avatar
AccordVT
Ian
Here are a couple Pic.s You can see that it's not wearing correctly also That Rotor is like 3 Months old and it's already rusting Ahhh Sears Genuine Parts
Originally Posted by foot
DOWN WITH SEARS!!!
File Type: jpg
File Type: jpg
Old Jul 29, 2005 | 01:14 PM
BNaccord2k1's Avatar
BNaccord2k1
Most rotors are going to rust when they are exposed to moisture. Its bare steel what else do you expect?
Old Jul 29, 2005 | 05:39 PM
Nirvanaspartan's Avatar
Nirvanaspartan
does anyone hear have some pictures for the structure for the rear discs for a 91 accord lx
Old Jul 29, 2005 | 07:41 PM
AccordVT's Avatar
AccordVT
Ian
I know, I just like finding ways to pick on Sears
Old Aug 1, 2005 | 01:11 PM
JimBlake's Avatar
JimBlake
The rust is normal. What isn't normal is how the rust isn't rubbed off evenly under the pad. Pull the caliper pins, remove the pads. Look for something uneven at the pad backing plate. Maybe the shims or anti-rattle springs are installed wrong? Maybe it's something as silly as a piece of crud in there, so the caliper isn't pushing evenly on the pad.
More serious things to check for...
Caliper or it's bracket is bent, so it's not perfectly parallel with the rotor.
Caliper slide pins are badly worn, so they're rattly/loose in their holes.
