Changing Transmission Fluid
Old Apr 15, 2005 | 03:50 AM
jmg's Avatar
jmg
It cost me about 10.60 dollars. Unless you include the fluid transfer pump, which you can use over and over again, about 23 dollars and 20 minutes of my time.
When you go to the Honda Stealer to get the MTF they will ask you if you need the crush washers, if not ask them.
Old Apr 15, 2005 | 05:56 AM
strykernyc's Avatar
strykernyc
damn thats alot of money. i just did mine yesterday. I went to the honda parts & service and got myself some honda ATF $14.83 total and i didnt have time to do it myself so i took it to some shop i go to and they charge me $15. so the total $29.83 and i do this every 6months since i have a auto and has no filter. manual is every year. anyway is extremely easy do change it i just dont have the space or time anymore to do it myself.
wow it feel so smooth feels like my car is brand new again 96accord4cyl slowmotion auto.
Old Apr 15, 2005 | 06:49 AM
jmg's Avatar
jmg
Yeah the MTF is 5 dollars a qt. My 96 Accord takes 2 qts. Plus two washers at .30 each.
Old Apr 15, 2005 | 06:51 AM
strykernyc's Avatar
strykernyc
oh, the auto takes 3 & no washer. interesting i didnt know mtf take less.
Old Apr 15, 2005 | 08:33 AM
redgoober4life's Avatar
redgoober4life
I eat plastic.
Drain and fill per Honda's recomendations is 2.5 qts for the auto, I'd have to look up the manual requirement. It's important to remember that the entire 3 quart capacity isn't going to be fully drained out. Also for the auto the interval is 30k miles, AND the drain/fill is what is in the service manual (a flush with a t*tec system is not necessary). Honda does have a flush procedure that takes 12 quarts of ATF, but it's only advisable as needed.
Old Apr 15, 2005 | 10:07 AM
jmg's Avatar
jmg
The Honda Service Manual for 96 Accord LX 5SP is 2 qaurts at drain and fill.
Old Apr 25, 2005 | 10:36 AM
digitalbreach's Avatar
digitalbreach
'00 Accord
Originally Posted by jmg
The fill bolt is above the drain bolt. Fill it with the tire off. Use a fluid transfer pump. On my 96 Accord this is what I did. Take off front passenger tire. Drain oild fluid out. Put blot with new washer on. Take fill bolt off stick the fluid transfer pump hose in the fill hole and the other hose into the qt. of MTF. Pump away. Did the same with the 2nd qt. It started "spilling" out of the fill hole I stopped ( 2qts. of MTF just as the Honda Service manual said). Replace washer and screw down fill bolt. Put tire back on. Got into car went through the gears. Started the car. Went through the gears.
Went for test drive, checked for leaks.
Go to AZ and get a Fluild Transfer pump, they are 10 bucks. Its pretty self-explanitory and easy to use.
Takes 20 mins.
GOOD LUCK!!!
Thanks for the help, really appreciate it. Great instructions.
How often should I change the transmission fluid from now on???
FYI
I filled my car from the top, so i didn't have to buy a transfer pump. I took off the cap and used a funnel to fill it up. My 2000 accord coupe only took 2 quarts. Also I hear that the cap should remain because it allows air in your transmission.
Old Apr 25, 2005 | 01:42 PM
jmg's Avatar
jmg
great! you had it easier than I did for sure!
