96 timing belt
Old Feb 25, 2005 | 06:10 PM
pkugao's Avatar
pkugao
Default 96 timing belt
I am a newbie. I have a question. My car is 96 accord around 60000mi. Should I replace the timing belt? Thanks a lot!
Old Feb 25, 2005 | 06:28 PM
ACCORDDUST's Avatar
ACCORDDUST
ChicagoLand Accord Club
yaaaa i have a 98 accord with about 90k should i change mine lol
Old Feb 26, 2005 | 04:48 AM
as_merrill's Avatar
as_merrill
aka FlamedAccord
wait till 90k. that is when it is recommended. while you are at it, change the water pump too, they should only charge you parts, because they have to remove it to install the new timing belt, so there is no extra labor.
Old Feb 26, 2005 | 06:24 AM
kevinthefawker's Avatar
kevinthefawker
well its recommended to replace it anyways even if its at 60,000 because it has been almost 10years and the belts can snap because they are old. so just do a timing belt powersteering belt and ac belt and alternator belt get all the seals changed the cam seal crank seal and change the water pump and you should be good up to another 100k if you use honda parts
Old Feb 26, 2005 | 09:47 AM
jobrien's Avatar
jobrien
If your car is that old and/or if you do not know all the car's history, go ahead and do it. I have a 95 and they recommend 90K. However, to the other guy's point, the belt (no chain) can just get old obviously irrespective of the miles.
Have them replace the water pump as well. They'll have everything torn out to do the timing belt. You wouldn't want them to have to re-tear out everything just for a water pump later down the road and charge you all that labor again. You may also want to ask about the balance shaft. AND BE SURE to have them replace any of the appropriate seals while they're at it too. No sense in skipping that part only to get/find a leak a little bit later on.
I feel like the dealer is the best place to have this type of work done. My EX has over 183K miles on it; and I'm (over) due for my second timing belt, etc. For the timing belt, water pump, balance shaft, and seals, its going to be around $620 give or take.
Old Feb 26, 2005 | 04:38 PM
abe1812's Avatar
abe1812
I have a 92 Accord LX with 128,000 miles on it. I went to Pepboys today and had a high mileage oil change and major tune-up for $391.00 . The service manager quoted me a price for a timing belt replacement as just over $510.00 . This price includes the water pump and new seals and gaskets. Am I being ripped off ?
Old Feb 27, 2005 | 06:27 AM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
You can pay that price or less at the dealer or a more reputable mechanic who specializes in Imports. I'd go some place else.
Letting them do shocks or brakes is one thing, but a timing belt is something Id leave to someone else.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old Feb 27, 2005 | 07:35 AM
abe1812's Avatar
abe1812
Thanks for the heads up, Im a newbie when it comes to cars
Old Feb 28, 2005 | 01:37 AM
strykernyc's Avatar
strykernyc
did u guys see the post with the broken belt off a 97 acura? that car only has 68k miles so i wouldnt play around waiting cause u never know
Old Mar 4, 2005 | 11:43 AM
jobrien's Avatar
jobrien
Go dealer for timing belt, etc. Others just aren't worth what LITTLE you may save.
Think about it... $5XX at a Pep-Boys... or $6XX at a HONDA DEALER.... Hmmm....
