DIY side molding shaving?
Old Aug 20, 2002 | 07:52 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default DIY side molding shaving?
Anyone performed this on thier own? I think my 5th gen would look alot better w/o the molding. Im thinking it wouldn't be too difficult to perform this. Remove the moldings, remove the inner door panel and plastic to access the inside of the door. Lay a strip or two of fiberglass on the inside of the door covering the holes where the moldings mounted. Then sand down the area where the moldings were, bondo, sand some more, primer,paint and enjoy your finished product. Sounds easy but has anyone done it themselves?
Old Aug 20, 2002 | 08:17 PM
aux's Avatar
aux
More Black on Black Crime
bumnah did his.
https://www.honda-acura.net/forums/s...hlight=molding
:thumbup:
Old Aug 20, 2002 | 09:26 PM
dantastic's Avatar
dantastic
cx power!
umm..... i had mine welded, then bonded smooth. its how most body shops doit.
Old Aug 20, 2002 | 10:41 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
you must have the $$$ to do that, I don't. I can only do the cheap mods, or the ones I can do myself. Im broke as hell bro.
Old Aug 21, 2002 | 12:42 PM
dantastic's Avatar
dantastic
cx power!
my car was rear ended, and pushed into the car in front of me. ins $$ covered shaving my sides, washer nozzles, rear trunk seam, and full bodykit. i lucked out i guess :thumbup:
Old Aug 21, 2002 | 01:17 PM
4Gen4DoorAccord's Avatar
4Gen4DoorAccord
I love rice...w/ teriyaki
Well if you use your bondo idea and what he did really soon the bondo will break and everyone can tell how ****ty of a job it was and if you paint it by then, well, you will be in BIG trouble. So basically find a buddy that can weld, weld metel covering the molding to sit flush, then grind down the welds, spread bondo, and sand. Then you know you have done a good job. If you need any other tips on shaving or custom work, feel free to ask. Dave
Old Aug 21, 2002 | 01:37 PM
kleankord's Avatar
kleankord
muahaha the pic in your sig is badass 4G4dr MaD props
MarylandHonda
Do It Yourself
10
Jan 13, 2009 08:51 AM
aschek
92+ Civic/EL & Del Sol
7
Apr 16, 2005 07:20 AM
