Rear End Noise
Old Sep 12, 2004 | 06:37 AM
smackdown's Avatar
smackdown
Default Rear End Noise
Recently replaced all the discs and pads on my 99 Accord EX-L. Since that time I have noticed a tremendous amount of what I can only describe as road noise. It appears to be coming from the rear only.
It increases with increasing speed. Does not change when I shift into neutral(so not a transmission problem). So it seems to be a rolling issue associated with the tires or wheel bearings or something I haven't considered yet.
I have pulled everything apart twice to make sure I put it back together right and everything appears fine.
Is it possible that this is a rear wheel bearing issue? Are they sealed bearings or can I go in and repack or replace them?
Smackdown
Old Sep 13, 2004 | 09:33 AM
when wheelbearings go bad, you can't miss the noise. it's a loud and annoying HUMMMMMMMMMMMMMMM. no matter if you roll up the windows, crank the music, drive fast or slow, you'll get the noise.
i'm pretty sure they are a sealed unit and you'll have to replace the entire part, not repair it.
Old Sep 14, 2004 | 03:43 PM
smackdown's Avatar
smackdown
You were right. Replaced them both tonight. Sound is gone. They were pretty rusted out. One of the races was stuck to the shaft.
I had trouble locating a torque spec for the main nut.
Can anyone offer up a number for the torque?????????????????
Old Sep 14, 2004 | 07:43 PM
Bruce_Willis's Avatar
Bruce_Willis
Do it Now!
Just had mine replaced.... sounds like new
Old Sep 14, 2004 | 11:07 PM
wedrine's Avatar
wedrine
I think im having the same problem with my 2001 accord, so just wondering, How much did the wheel bearings cost?
Old Sep 15, 2004 | 06:36 AM
smackdown's Avatar
smackdown
$95.59 each. Install is easy.
I'm still looking for a torque specification though for the nut that holds the hub in place. I bought a service manual but am waiting for delivery.
Until the manual comes, I tightened the nut enough to seat the hub, backed it off, then resnugged it and deformed the nut again.
Old Dec 30, 2004 | 06:50 AM
waltzee's Avatar
waltzee
Default bearing noise - easy to replace bearings yourself, save $$?
Hi - what happened with your bearing problem?
i drove both a 2000 and a 2002 and the 2002 was quiet.
I am surprised that this problem *seems* to happen as often as it does.
Aren't the bearings sealed?
I also think you have to replace the hubs w/ the bearings (about 85 bucks per wheel - parts only), it LOOKS easy to do, anyone DIY this job themselves?
shopping for 2000-2002 EX accord coupe, 4 or 6 cyll
thanks - waltzee
Old Dec 30, 2004 | 08:00 AM
waltzee's Avatar
waltzee
Default By 'rear end' i mean rear wheel bearings....why do they die so fast?
sorry for the poor title on original post. i am test driving accord coupes, 2000-2002 and am surprised that 2 out of 5 have had significant rear bearing noise.
is this common in these cars?
i am looking at EX 4 or 6 cylinder versions (depending on price)
thanks - waltzee
