Water pump problem?
Old Mar 8, 2004 | 04:31 PM
vegas_accord's Avatar
vegas_accord
Slow and Low in Vegas
Default Water pump problem?
My 96 Accord has 75000 miles and has developed a squeek in the area around the belts and pulleys. Could this be my water pump going out? The squeek goes away when the car heats up and sometimes during deceleration.
Old Mar 8, 2004 | 04:37 PM
i know that squeek. with 75K on the clock, you might want to look into getting your timing belt and water pump replaced. it's basic maintenance that should be done. (i'm not too sure of the exact mileage it should be done on the 5th gens though)
Old Mar 8, 2004 | 05:01 PM
Tom T's Avatar
Tom T
90K recommended for that era.. Sounds like potentail Water Pump to me as well. Have someone check it out...
Good luck...
Old Mar 8, 2004 | 05:30 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
I'd check all the belts, i've had that feeling that i'd have to do the timing belt again! but found out that it was only the alternator belt! check em.. also the alternator belt is only like 8 bucks, won't hurt to change.
Old Mar 9, 2004 | 03:28 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
generally when a water pump fails it will start to leak coolant from the seals. check your coolant level and look for drips under the car.
Old Mar 9, 2004 | 06:02 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
This is true.
Also,.. you can tell if you listen closely,.. you can hear the water pump make a rattling sound. Kind of like maracas.
Then the leaking will occur.
rivvin
4
Feb 10, 2004 11:16 AM
one11racing
Oct 1, 2002 07:00 PM
Hondalos
Engine Swaps, Tech & Tuning
Sep 18, 2002 07:54 PM
Momobile
Accord
Sep 11, 2002 01:13 PM
REbornHONDAneer
Accord
9
Aug 18, 2002 04:22 PM
