h22a / 5 speed swap, need opinion
So I'm seriously contemplating doing one... what do you guys think? Maybe even a f20b swap... I mostly want to do it with the stick, because It would be pointless to swap in an auto h22. Anyone here done the h22/manual conversion? or know of anyone who has? How reliable will this setup be?
I have seen several cars with thtis swap first hand and they have been as reliable as any other H swap. The manual tranny swap really isn't all that tough to do but to make it look like it belongs there takes a little work....a good mechanic with a solid swap history should have more than enough know how to accomplish it.
i paid a shop to do my H22 swap with the 5sp conversion. they welded the clutch pedal bracket just like stock and i even have a 5sp cluster. i also had them use a 92-96 lude shifter so it looks shorter/cooler. the only negative is that if you try starting the car w/out the clutch depressed it will lurch forward and you have to make sure they use a guage cluster that corresponds to your car ie. 2dr or 4dr cause a 2dr cluster won't trigger the dome light and stuff on a 4dr...don't ask me how i know
h:
h:
Im doin that swap in around a month. It was suposed to in this month, but had to take care of dental work first. (braces owned me)
h: . But doin 5-speed / H22 soon at a local shop. Also, dont go with the F20B unless you got mad cash.
h:
h:
i went through www.a1jdmengines.com i paid 2,200+ shipping, but this was 2 years ago and prices have come down. i have put 25k on motor and it dynoed 182whp and 150lb/ft trq which is are pretty nice numbers.
Originally Posted by drmmrboy87
so how much did the install cost?
$900 for motor swap+$400 for 5sp swap=$1300 for labor
you also need about $500 for 5sp parts and about $600 in maintenance items including a new clutch.
