Suspension Help!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 3, 2004 | 08:02 PM
jtaccordvtec's Avatar
jtaccordvtec
Default Suspension Help!!!!!!!!!!!!!!!!!!!!!!!!!!
hey everyone, i am planning to upgrade my suspension on my 1998 v6 accord coupe. i am confused to some extent on what is what?
for instance, can someone define what is a strut and shock? do i need both? how do they work together, and what exactly do i need to buy(shocks, struts, springs, camber kit?) to upgrade my whole suspension? and as for the adjustable shock, how would we adjust them and is it difficult to adjust them(do i have to raise my car up to adjust them?)
any response would be appreciated.
Old Feb 3, 2004 | 08:30 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Folks will argue all day about the strut/shock thing, their the same thing just called different on different cars. I call em struts and u don't NEED new struts unless ur doing a big drop. In that case it would be good to upgrade ur stock struts to aftermarket ones such as Koni Yellows or KYB AGX. Adjustable springs are coilovers and not that hard to adjust. As for camber kits, those are necessary if ur dropping your car mass amounts as well. I would say anything over 1.3-1.5 a camber kit would be a good idea. Hope this helps!
Old Feb 4, 2004 | 01:31 AM
JustOneMore's Avatar
JustOneMore
Basically, when you hit a bump...the Spring is what allows your car to compensate...but if you think of physics, when you push against a spring, it'll push back...overextend, recompensate...and go back and forth continuously until all the energy is returned to normal. So, obviously if your car only had springs, any bump on the road would make your car go crazy. Shocks primarily control dampening...which is basically absorbing the energy from going completely into the spring. Shocks eliminate (as much as possible) the "back and forth" that the spring would otherwise create...returning the car back to neutral stance after absorbing a bump/ditch.
Now, you want to get aftermarket suspension...springs that lower obviously have to be more progressive...think "stiffer"...because if it was as "soft" as stock springs...it would need as much distance to travel to absorb a bump
(otherwise you'd bottom out and tear apart your car on big bumps). Keeping the increased progressiveness in mind, the shock must now do the same job as before and be able to dampen the bump and return car to normal. Since the springs are more progressive...the shocks have to do more work...stock shocks aren't designed to handle that much compensation...(in fact, this is good because high dampening also = less comfort).
Adjustability for shocks just means you can control the dampening rate...how "fast" you want your shocks to compensate for the spring movement/return car back to normal. I personally love this feature and that's why I chose koni yellows...
SO, in the long run, you will need aftermarket shocks to go with your aftermaket springs...simply because the stock shocks will wear out. Some people can get away with just keeping their stock shocks when they dont' lower too much...it's just wearing out the shocks slower... The lower you go, the more progressive the spring, the more work the shock must be able to do. Koni Yellows are great and very well designed, people go 2"+ with them and have no problems...but if you are only looking to lower ~1.2", koni reds or tokico blues etc would be fine. KYB AGX are also GREAT shocks and they are very well priced for adjustables. A friend of mine had these with Eibach Sportlines (2.2" drop) and it ran fine...going on 2 years now.
Hope this helps! Good luck with your mods.
Old Feb 4, 2004 | 06:46 PM
jtaccordvtec
thanks sire, appreciate it.
Old Feb 4, 2004 | 06:55 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
you have !!!!!!!!!!!!!!!!!!!!!!!!! unessacary !'s in your title
j/k get teins that way everythings taken care of and the rides about stock comfrot and full adjustable height and stiffness/softness. mines 6 from hard in the front and 8 from hard in the rear and comfort is close to stock, they go all the way up to 16, so yeah you can make that bitch ride like a boat, lol
Old Feb 6, 2004 | 05:38 AM
Bl@ck's Avatar
Bl@ck
Sinner
WRONG!!! the thing that distinguishes a shock from a strut is that struts have a brake line mount on them and shocks do not.. please, on this forum, if you're gonna tell someone something at least do the research and find out for sure that you know what you're talking about before you pass on misinformation.
so to answer the original question, struts in the front, shocks in the back, springs depend on what drop you're looking for and camber kits depend on how low you want to go. if you're a little more specific about your wants then we can probably push you in the right direction.
sirDANG
92+ Civic/EL & Del Sol
7
Jan 21, 2003 12:10 PM
eclipse spanker
4
Dec 2, 2002 07:18 AM
Redcivic
8
Oct 22, 2002 06:31 PM
92 wagon
Accord
6
Oct 14, 2002 03:24 PM
BonzoAPD
13
Aug 7, 2002 05:27 AM
