Replacing Wheel Studs help
Old Jan 1, 2004 | 03:32 PM
CivicExpy's Avatar
CivicExpy
and i bet they arent the same way. and yes i know what they look like since i've done it 3 times. they wont press right out of the back. why is it that the 4th and 5th gens have the 4 bolt holding the rotor from the back and the 6th gens dont? the 6th gen rotors and held on by 2 screws unlike the 4th and 5th gens. why arent the rotors the same? have you ever done a 6th gen?
Old Jan 4, 2004 | 08:11 AM
CivicExpy's Avatar
CivicExpy
you guaranteed that you were right and havent proven me wrong
so am i right or wrong?
show me up big powerful H22
Old Jan 4, 2004 | 01:33 PM
JayDub96's Avatar
JayDub96
Default Still need help
Ok..
My attemp at doing this has failed.
I was able to get the spindel off but couldn't get the 2 screws out.
Does anyone have any sugestion on this process?
Old Jan 4, 2004 | 02:25 PM
CivicExpy's Avatar
CivicExpy
Default Re: Still need help
Originally posted by JayDub96
Ok..
if youre talking about the 2 screws that r holding on the rotor then you should use an impact screwdriver. what it is is a big screwdriver that you hit the end of it with a hammer and it will slowly turn out the screw. then once you break it free just use a regular screwdriver
Old Jan 4, 2004 | 02:36 PM
JayDub96's Avatar
JayDub96
Is this the only way to do it?
I don't have a impact screwdriver.
Is it exspensive? Should I buy one?
Thanks for the help
Old Jan 4, 2004 | 04:46 PM
HondaSociety's Avatar
HondaSociety
JayDub you have a PM explaining everything
Old Jan 5, 2004 | 02:46 PM
HondaSociety
come on Xoned. you guaranteed me that i was wrong. show me i'm wrong and i'll shut up
Old Jan 6, 2004 | 06:58 AM
JayDub96's Avatar
JayDub96
Ok...I wasn't able to do it but found out that it's not the same as the link explains for the 5th gen Accord. You can't get to the studs after you take off the caliper mounting bracket. There's a hub or what ever you call it on the other side of the rotor that prevents the stud from comming out the back of the rotor. So I took off the rotor that is held on with two screws that were so tight that I almost gave up. Once you take the rotor off I was told you can get that hub off with a block of wood but it's best to have a shop do it with a press that pulls it off evenly.
Old Jan 6, 2004 | 02:39 PM
HondaSociety
thanks Jay. Xoned do you still guarantee me that the 5th and 6th gen spindles are exactly the same?
Old Jan 10, 2004 | 06:15 PM
JayDub96's Avatar
JayDub96
I took my car to Midas today to have the stud replaced.
I waited for service longer than it took the guy to fix it (15min tops).
It only cost me $40.33
