Replacing Wheel Studs help
Old Dec 27, 2003 | 01:47 PM
jbizanks's Avatar
jbizanks
Default Replacing Wheel Studs help
This simple task isnt so simple for me.
On my front driverside the studs go are poked through the back of this plate, in front of the rotor, i can't figure out how to get that plate off it (after getting the 4 bolts to the rotor).
It apears to be attached to my cv axle, has anyone replaced these or your rotors in the past?
Any help would be apreciated.
93Accord EX
Old Dec 27, 2003 | 04:21 PM
slpycd7's Avatar
slpycd7
H22 fo lyfe!
http://www.spyfunkr.com/accord/studrepl.htm
that should help.
Old Dec 27, 2003 | 05:55 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Excellent tutorial
Old Dec 29, 2003 | 02:12 PM
jbizanks's Avatar
jbizanks
Awesome that did help!
Old Dec 31, 2003 | 07:32 AM
JayDub96's Avatar
JayDub96
I just broke one one 01.
IS i the same process?
4cyl Accord.
Old Dec 31, 2003 | 07:02 PM
slpycd7's Avatar
slpycd7
H22 fo lyfe!
4cyl Accord.
:doh:
Old Dec 31, 2003 | 07:35 PM
CivicExpy's Avatar
CivicExpy
Originally posted by XonedReality
:doh:
is that supposed to mean something? if youre saying that because you think its the same then youre wrong
on the 6th gens you need to take off the spindle. press out the wheel bearing. then press out the studs. then do it in reverse. its not as easy
Old Dec 31, 2003 | 09:11 PM
JayDub96's Avatar
JayDub96
CivicExpy,
Thanks for the info.
I guess I'll take it to a shop to have it done.
Old Jan 1, 2004 | 03:56 AM
blurr
Guest
Posts: n/a
uhh.. no you don't.. who told you that?
it's done the same way
Old Jan 1, 2004 | 08:48 AM
slpycd7's Avatar
slpycd7
H22 fo lyfe!
:werd:
go look at a 6th gen spindle, then go look at a 4th, and 5th. OMG they are the same! except for the fact that the suspension is different in the 6th than the 4th and 5th generations. The lugs are done the same way. i guarentee it.
