1991 accord ignition problems
Old Jul 18, 2002 | 12:06 PM
drfred's Avatar
drfred
Default 1991 accord ignition problems
Under hot weather conditions my 1991 accord EX with 140,000 mi will not crank. The motor turns over but seems to be getting no fuel. Most of the time waiting for 10 minutes is enough to allow the engine to crank. This problem has existed since the car was purchased in 1998. Initially the problem was sporadic but now is quite frequent. I have just replaced the high pressure fuel filter and distributor. No computer codes show up to diagnose the problem. Engine light stays on too. Gas cap tightened correctly. The time interval required to start the car seems to be increasing from 10 minutes to several hours before the car will crank.
Old Jul 18, 2002 | 12:37 PM
drfred's Avatar
drfred
Just changed the distributor, rotor, new spark plugs and wires. Haven't changed the starter.
Old Aug 6, 2002 | 11:05 PM
AccordManiac's Avatar
AccordManiac
Korean Member
I am pretty sure that you need to replace the
"MAIN RELAY Assembly"
Very common problems for 4th / 5th generation Accords..
http://www.hondainfo.com -> under trouble shooting
90' - 97' Accord
Won't start, not getting fuel (in hot weather)
Main Relay Assembly (R&R)
327985
$ 52.00
Old Aug 7, 2002 | 05:13 AM
GimpyAccord's Avatar
GimpyAccord
90' - 97' Accord
327985
$ 52.00
i Agree.
Old Aug 7, 2002 | 05:42 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
knew someone who had the same problem. changed the realy still have the probom. Found out is was the ignition box. So he just shelled it out and went MSD all the way. Damn she moves like nver before;o)
Nelson
Other Honda & Acura News
May 1, 2014 11:20 AM
themilman
7
Dec 28, 2006 06:56 PM
sick79
CRX & Pre 92 Civic
Jan 13, 2004 10:53 PM
gore
Accord
3
Jul 8, 2003 10:30 AM
