I replaced, Cap, Rotor, Wires, Plugs, ignition Coil, and Ignition control, AND NOTHIN
Well, I was doin' a tune up on my friends accord, because he said it was acting funny. So I cahnged out the Cap, rotor and wires. Then I slaped it back together and it wouldn't start. No spark. So then I replaced the ignition control module, and STILL, nothing. So then I had my Mechanic test the coil, and he said ti was bad. So then tonight I replaced that. I try to fire up the car, and nothing STILL? All the fuses are intact, and I can't seem to find a fusebox inside the car, IDK if it has one. But then, IDK what would warrant this no spark situation. Also I took off the distributer and put it back on, and if i am correct there is only one way to put on a Honda Distributer, because of the notch in it. I put it back on the right way, But it WILL NOT FIRE. Any suggestions?
bboy Wesley West
Originally Posted by RedlineBoyzCRX
where is the Main PGFMI fuse?
check for the click when you turn your keey to "II"
No spark?, does it spin over if it does should'nt be main fuse, what year?, several years had problems with distributors(not cap and rotor, dist. itself).....common with high miles 98 and older......check for tech service bulletins....some had extended warranties from Honda.
lots and lots of fail
1 Post
I can smell the fuell, it cranks over and all that, but i get NO spark coming out of the plug wire. I recently replaced the Idnition module and the Ignition coil, and none of that did anything. What would make it not give a spark?
