turbo y8 cooling problems
Originally posted by NeverBX
heres a link to one on ebay. cheap.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2433907240
The part is $4.99 and shipping is $20. There's no way.
i dont know if putting a stock replacement in if that will help. i was looking at a after market electric pump which is 350 $. i talked to this guy from BE COOL he said by changing the radiator the stock pump cant flow as good b/c it is made to flow with the smaller stock radiator.
Yes, it does. If you don't have your car tuned for the turbo you can run lean. If you run lean, you run hot. Another problem is detonation (due to lean conditions, check your A/F ratio), I have seen some people that recommend retarding your timing to also help the whole lean condition situation. Though not all applications call for this tuning, I have heard of it being a problem. Don't take my word for it (what do I know right?). Check this site out:
http://www.turbo-kits.com/honda_turbo_kit_faqs.html
Hope this helps--Air
I ran my car on a fmu with shitty airfuel untuned for 6 months in the texas 100+ degree heat and then i tuned it with an AFC, it made no difference in overheating, i guarantee you it's something else.
Originally posted by reddemon009
my car is tuned and if anything im running a lil rich. its gotta be something else.?
