turbo y8 cooling problems
Old Sep 24, 2003 | 11:04 AM
reddemon009's Avatar
reddemon009
Default turbo y8 cooling problems
i have a 98 turbo ex, which runs very hot, i cant keep it cool. i have a after market radiator 1.25 in. thick and i still over heat.i even wired my fan to be on all the time. would taking out the thermostat help? or that stuff you add in to the antifreeze ? or even a electric water pump ? any info would help thanks.
Old Sep 24, 2003 | 12:13 PM
Civic Type Sev's Avatar
Civic Type Sev
You could try an oil cooler. Oil also participates in cooling the engine so the cooler it is, the more cooling it can do while running through your engine and since you're running oil through your turbo... it's hotter than usual.
Old Sep 24, 2003 | 12:19 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
SleeperCivicEX is a '99 turbo Y8 and he has problems too. We've done everything short of replace the water pump and get an oil cooler.
He's running a Fluidyne, FAL fan, cut thermostat and new temp sensor. We're kinda baffled about it, but think that it may be the water pump.
An oil cooler can never hurt.
Old Sep 24, 2003 | 01:23 PM
Mike99's Avatar
Mike99
U.S. CoastGuard
I don't have any trouble in texas heat with the A/C on. the only thing I did is change my waterpump when they tore down my engine. Maybe it is the waterpump?
Old Sep 24, 2003 | 01:55 PM
ManTiS's Avatar
ManTiS
NinJA
I have absolutely no problems.
Never do anything to the thermostat except get a new one.
I run stock fan, radiator water pump, and new thermostat and radiator cap. It's always at 1/3
Old Sep 24, 2003 | 03:07 PM
SRT_Andy's Avatar
SRT_Andy
I really think it is. If I replace it and it still overheats, I'm going to be so pissed! It doesn't happen all the time, nor do I have to be racing for it to overheat.
Old Sep 24, 2003 | 03:26 PM
reddemon009
yo SLEEPER you and me have the same problem. the company BE COOL has a high flow thermostat i wonder if that would work? or even take it out completely. has any one ever done that? i really dont wanna get a new water pump b/c they run about 350 $.
Old Sep 24, 2003 | 03:32 PM
westcoaststyle
An OEM water pump is not $350. I got one for my brother's D15B7 for like ~$40 FROM HONDA.
Sleeper has removed his thermostat.. you have to cut out the center, you can't just remove the whole thing because it also acts as a gasket h:
Old Sep 24, 2003 | 03:45 PM
ManTiS's Avatar
ManTiS
NinJA
Your motor "should" be okay with the thermostat still installed. If it's not, then you have to look at other causes.
Old Sep 24, 2003 | 03:50 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
wow i don't have any problems and it's 100 degrees out here in the summer. Hell its' still 90's right now and i boost it around town at 8 psi all day long. I'm on a bone stock cooling system with a 30X6X2.25" intercooler
Try adding some redline water wetter to your coolant, it really helps. I tested about 30 degrees cooler with the OBD2 reader after i put it in. Or just get a bigger front mount
