More power out of my CRV/Vtec Motor...
Old Sep 13, 2003 | 09:08 AM
  #41
Timmet93's Avatar
Timmet93
$8200...will list everything done to it if you are interested!!!
Old Sep 13, 2003 | 01:40 PM
  #42
Slammed_Civic's Avatar
Slammed_Civic
i know this is a little off subject but i have the b18b motor iv seen some one put a b20 head on it does that evan make a difference?
Old Sep 13, 2003 | 01:41 PM
  #43
Snoopy's Avatar
Snoopy
been there done that
not really
Old Sep 13, 2003 | 07:47 PM
  #44
white_n_slow's Avatar
white_n_slow
it's my D in a B
nope. The LS head and B20 head are identical, as far as I know.
Old Sep 13, 2003 | 08:08 PM
  #45
Kai's Avatar
Kai
Rotorphile.
Yup, both are PR4 castings. Both even have 81mm combustion chambers, even though the B20B/Z has an 84mm bore.
Old Sep 13, 2003 | 09:17 PM
  #46
PHiZ's Avatar
PHiZ
BOOST GOD
Yeah, the CRV-tec will have the same R/S problems as the LS/vtec. Yes above 6grand you are having serious sidewall force applied on your sleeves.
Dyno tune that rom.
Vortech superchargers are dyno queens, and are not going to help his lower end.
Old Sep 14, 2003 | 11:35 AM
  #47
Slammed_Civic
i know i can find this by looking in the archives but sence this is already going what are some of the problems with mating a non-vtec block with a v-tec head?
Old Sep 14, 2003 | 07:54 PM
  #48
Snoopy's Avatar
Snoopy
did you even read this thread? :eh:
and its vtec :squint:
Old Sep 15, 2003 | 08:04 AM
  #49
Slammed_Civic
yes, here ill make it a little more specific, not only do the ls-vtec and crv-tec fail at high rpm do they also leak fluids and need more maintenance than a regular built motor?
Old Sep 15, 2003 | 11:12 AM
  #50
Timmet93's Avatar
Timmet93
My crv/vtec motor has had no problems and Ive been driving it for over a year. i had teh head all done by JG Engineer. It drives great but I have a idle problem. Nothing major. I have a very small oil leak coming from teh block but i cant pin point it. I recommend crv/vtec motor swaps. They have good power.
What ecu could I run to get the most out my motor? Or should I just buy a apexi vtec controller? Also i want cams...I have a my head all built with titanium internals so how big of cams can I run?
