Need Help with Brake Swap!!
Old Aug 26, 2003 | 02:03 PM
wilsel's Avatar
wilsel
Default Need Help with Brake Swap!!
My car is a 95 EX, and I just bought a rear disc conversion from a 95 EX w/ABS. The only thing he did not send me is the brake booster, and prop valve. Will the master cyclinder work okay with my brake booster? Anyone know if it'll line up with the brake lines without reflaring? Also what about e-brake cables, can I use my existing ones, or do I need ones from a teg?
Thanks!
Old Aug 26, 2003 | 02:58 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
i thought all EX's came with rear disc brakes already? :dunno:
if it's an abs master cylinder, you might have to reflare one line. that line going into the abs master cylinder is larger than non-abs because that larger line feeds all of the fluid going into the abs unit.
Old Aug 26, 2003 | 03:20 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
only sedans.
Old Aug 26, 2003 | 07:57 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I don't know for sure if the master cyl will work with your brake booster, but you can just keep using the stock MC and booster for now, as with the prop valve. I personally had a helluva time matching boosters and MCs, and I'm running the stock ones right now with my teg f/r brake swap. As for e-brake cables, you'll need either 4 door integra ones, or 4 door EX (w/ disks) ones. The 4 door ones are a little longer than 2 door ones.
