So I took my slow ass car to the track
Old Aug 21, 2003 | 04:50 PM
fook's Avatar
fook
Boosted D Series
Originally posted by New93Civ
I think the 17's slow the car down a lot
I hope so considering the EX coupe is rated at a 16.8 stock...course amateurs dont usually hit stock times.
Old Aug 21, 2003 | 05:00 PM
New93Civ's Avatar
New93Civ
I dont have the slip no more it was from like april, but I think it was between 84-86 I cant remember. I going back to the track this weekend tho. I gonna put on an MSD external coil and an SCI ingnition controler to I hope that my DRs are in Sat morning. I got the BFG g-force drags. On my LS1 I used the Comp TA DRs and they were great. only lasted a short time though
Old Aug 21, 2003 | 05:02 PM
New93Civ's Avatar
New93Civ
Im looking to go into 14's some how. Has any one done it all motor D16z6. If I cant get in all motor i will squeeze a little Juice in there to give it a push
Old Aug 21, 2003 | 05:09 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
What's funny is how 17s will slow a honda down, 17s will usually help out a dsm... damn 32lb wheels.
Old Aug 21, 2003 | 05:11 PM
fook's Avatar
fook
Boosted D Series
mmm...dsm...
I need some parts off of one of those...SMIC, turbo, BOV...usual stuff...
Old Aug 21, 2003 | 05:18 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
my lx automatic sedan ran at best, 18.5. Complete with 27lbs rims, full interior and subs/amps/box
Old Aug 21, 2003 | 05:20 PM
fook's Avatar
fook
Boosted D Series
sometimes i feel silly for running a stock auto on the 1/4. Everything I did only got it CLOSE to the stock time of the 5-speed version of my car. But it was fun and I dont really do it much anymore.
I like the twisties.
Old Aug 21, 2003 | 05:23 PM
New93Civ's Avatar
New93Civ
Its still fun no matter what
Old Aug 21, 2003 | 07:21 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Default Re: So I took my slow ass car to the track
Originally posted by ZimZimma13
I have a 98 EX coupe with AEM CAI, Apexi WS catback, cheap ass ebay short shifter and nuespeed shift bushings. I took out my spare, but full interior and I still ran on my 17 in rims with kuhmo tires. I have KYB AGX's on thier stiffest settings, and ground control coils.
I thought I ran pretty slow. I got 17.161, 17.587 and 17.099. For what was running with is that ok? This was my first time.
Will I do much better if I run my stock steelies with a low psi?
My 60' were 2.557, 2.532 and 2.428. I spun my tires two times when I launched at 5000rpms, the first time i launched around 3900 or 4000 and the car bogged down a little thats why I upped the rpms for the launch.
Any advice on how I can improve my times with what I have? In time ill be doing more engine work.
your 60 foot is raping your ass hard...with a 2.2 you'd be solidly in the 16's. What was your trap speed? Did you lower your tire pressure to like 20-22 psi? When i had i/h/e on my ex i launched about 4500 at the track and pulled 2.2-2.25 all day long. A good launch is better than a boatload of boltons on an EX. With my current setup i pulled consistent 2.1 60 foots on my steelies and stock 175/65/14 dead firestones.
Make sure you heat up your tires, don't go through the water just pull the ebrake and heat em up for a good 3-5 seconds it helps a LOT.
When you launch don't just mash the gas and dump the clutch, you'll always spin. When you're staging rev up to your launch rpm and let the clutch out halfway (right to the point before it will engage at all) Then when the light turns green give it about 3/4 gas and let the clutch out so it catches, you'll start to spin up a little which is good. If you start to bog give it more gas and let the clutch out some more but do it all in SMALL INCREMENTS (i can't stress how important that is on the launch) When you hook up stomp the gas and let the clutch out completely.
oh yah, ditch the 17's they will KILL your times at the track. Just put your steelies or some smaller wheels on and lower your tire psi
good luck.
Old Aug 21, 2003 | 07:24 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
I ran a 15.8 with h/I no p/s or a/c. I have 2 1/2 inch exhaust all the way to the muffler. I went on stock steelies and ran great. I. going to go back with some DRs to knock a couple of tenths off
i don't know if dr's are gonna help you much if you just have i/h/e. What was your 60 foot on the steelies?
