Installed injectors HOLY CRAP!
Old Aug 11, 2003 | 02:38 PM
Jafro's Avatar
Jafro
I'm made of meat!
Default Installed injectors HOLY CRAP!
Yes. I'm definitely taking this back to the track to see what my budget swap can do. I can't believe how good it's running now! I mead DaYuM! It has more low-end torque (if that's even possible with a Honda)... much less a D15B7. I have yet to get it over 45mph, and love it already. I can't wait to see what it does merging onto the highway without check engine lights!!!
Thanks to everyone that offered suggestions for the home injector cleaning thread. What I did at home seems to be more than adequate (and free) for my egg of doom. I finally have a trouble-free bucket! (I'm already knocking on wood)
Old Aug 11, 2003 | 08:51 PM
Spood's Avatar
Spood
Sucka
Man...just think how bad you'd blow your load if you had swapped a D16Z6 into that CX...
Are you running the DX tranny or do you still have the CX?
Old Aug 12, 2003 | 09:53 AM
Jafro's Avatar
Jafro
I'm made of meat!
CX tranny. Believe me, it's fun. I only really need 1st, 2nd, and 5th gears. I'd be happy with just a 3-speed. I did this D15B7 swap because the stock motor was shot. It didn't turn out so bad considering how much lighter the CX is than a DX.
My other car runs low 13's, and I plan on breaking it a dozen times trying to make it run 11's, so I didn't need to go nuts upgrading my fuel efficient daily-driver.
Here's my mod list...
Worn-out 1992 CX, 105k miles $2000
Complete D15B7s w/Throttle body/manifolds/injectors - FREEBIE! ZIP! ZERO!
Engine gasket kit $90
Machining the block (.020 over+honing) - FREEBIE! ZIP! ZERO! NADA!
1 exhaust valve - $11
Deck the head, regrind the valves, 1-angle valve job - FREEBIE! ZIP! ZERO!
Polish the crank - FREEBIE! ZIP! ZERO! NADA!
Exide clutch/flywheel combo - $175
Rebuild oil pump - FREEBIE! ZIP! ZERO! NADA!
Water pump $35
Timing belt $28.50
OEM T-belt Tensioner $35
VX tach-$12
Stereo from my totalled 95 GS Eclipse - FREEBIE! ZIP! ZERO! NADA!
Generic 2" muffler-$25
Polished valve cover $11.50+ 16 hours of hand sanding
eBay CAI - $36
Cousin's auto shop with lifts & air tools - FREEBIE! ZIP! ZERO! NADA!
On less than a Monster Garage budget, I picked up over 40hp, and shaved over 2 seconds off of the car's 1/4 mile time; that was with the WRONG injectors, running lean, and detonating with no tachometer or clue where the redline was. With the right injectors, I can already tell it's faster, no more o2 code-1 CEL's, and it doesn't idle surge or hesitate anymore.
Not bad for a civic + a weekend + $450. How much is an AEM CAI new? What gains does that offer? PTPTPTPTPT! If you're resourceful, you can swap the whole engine for less than the cost of a cat-back.
My advice: Never buy bolt-ons for a CX. It costs less with bigger gains to swap them with a crappy motor than it does to mod the even-crappier motor they already have.
Old Aug 12, 2003 | 06:15 PM
90TGP's Avatar
90TGP
Try ebay for CAI's. Better deals then new ones.
Old Aug 12, 2003 | 09:09 PM
theguy387's Avatar
theguy387
fuuuck man that sucks those trannies for that gsx cost a left nut
Old Aug 12, 2003 | 09:11 PM
theguy387's Avatar
theguy387
nice car though :goodjob:
Old Aug 12, 2003 | 09:21 PM
Nelson's Avatar
Nelson
Administrator
So exactly which injectors are you using and what did you do? :thinking:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 12, 2003 | 09:51 PM
Jafro's Avatar
Jafro
I'm made of meat!
Sorry MaxBoost. I was mislead into believing that all 92-95 injectors on Hondas were the same. I was using the wrong injectors on my bucket and throwing codes. Finally I narrowed it down to the injectors, cleaned them myself (in a process described with a link in another thread named
"Home Injector Cleaning"). They weren't kosher, cleaning them fixed the last problem with my POS dx swap, and the car turned out better than I thought it would.
theguy387: I have an extra $2300 in it already, and it's broken only 7k after I did that to it. I'm about to drop in a quaife center differential, double synchro 3rd/4th gearset (to match the double synchro 2nd gear), and a top-speed 5th gear. The EVO forks are being updated (I broke a SS 1/2 Lancer Evo IV shift fork) I think it will be around $4000 in the end. I'm also dropping this http://tinyurl.com/junl turbo in with a FMIC and water injection. Worth every penny. I love pissing off V8's with a 2.0L.
heheheh... freakin' turbo costs almost as much as my whole civic did. I still like the civic, but the fact that I put a DX motor in it is taking a toll on my testosterone levels. Pretty soon, I'll be growin boobs.
Old Aug 13, 2003 | 12:34 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Originally posted by Jafro
FREEBIE! ZIP! ZERO!
someone watches too much monster garage :fawk:
Old Aug 13, 2003 | 06:56 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
coximport has the AEM CAI's overstocked right now. I just picked one up for 155 shipped for my 92 SE-R.
Jafro, so you didn't actually swap injectors just cleaned em out? What injectors size are the d15 motors? I have a set of 240cc's off my 00 ex that i don't need if you want em let me know.
