engine swap advice
Old Aug 9, 2003 | 04:57 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
...more work and more parts to buy, so figure a couple hundred more than that at least.
Old Aug 9, 2003 | 06:43 PM
arctic_giraffe's Avatar
arctic_giraffe
it's a siR I engine that i'm putting in, and why is a siR I harder than a siR II?
Old Aug 9, 2003 | 06:45 PM
Kai's Avatar
Kai
Rotorphile.
It has a cable transaxle and older electronics. You either need a cable to hydro adapter and mount or a hydrolic transaxle, plus you need an OBD-1 distributor and fuel injectors amoung other things.
Given that info, $1600 isn't such a good deal.
Old Aug 9, 2003 | 07:32 PM
arctic_giraffe
so would it be cheaper to just go with the Si R II? i can get that with mounts for about two grand. that way i have an easier time too.
arctic_giraffe
Old Aug 9, 2003 | 09:49 PM
Kai's Avatar
Kai
Rotorphile.
Going with the SiR II would be easier and it's rated 10hp more. That would probably be the wiser choice.
hmotorsonline has SiR-II swaps for $2350 with all the fixin's, you might want to make sure your guy provides all the stuff that Hmotors does.
Old Aug 10, 2003 | 06:49 AM
arctic_giraffe
The swap comes with :
Motor
Transmission
Engine Wiring Harness
All required Cables
ECU
Distributor
Complete Intake Manifold
Alternator
A/C
Power Steering Pump
All Brackets and Sensors
Shiftlinkage ($75 extra)
2170 plus shipping
that price is his price...i'd get the whole sale on that. i checked out hmotors but the site was down so i'm not sure if they offer more then my guy.
Old Aug 10, 2003 | 10:37 AM
pdooley's Avatar
pdooley
Originally posted by arctic_giraffe
ok...thanks everyone very much for the help. i'll deffenitly be doing the b16a swap then. i can get the whole swap with engine mounts for about $1600 then i finally just found a friend who is a mechanic and will do all my work for free. so i figured that's a good deal. again thanks. i'm sure i'll see everyone around here again soon.
arctic_giraffe
just curious how did you come across wholesale pricing?
Old Aug 10, 2003 | 01:35 PM
arctic_giraffe
i got the whole sale price because my friend (who drives an acura integra ls) is a really good web designer and made a deal with www.rimsandthings.com where he'd do their site if he could get whole sale prices. pretty cool deal actually...made me want to become a web designer but then i decided i didn't want to be a complete nerd.
Old Aug 10, 2003 | 02:27 PM
91Teg's Avatar
91Teg
From H motors
B16A 88-91 (SiR I) Motor, Tranny, Computer
Price: $ 1250.00 Plus shipping and handling.
Availability: In stock and ready to go
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
*Requires aftermarket parts for most applications. We can supply you with the hasport mount kit for $350 and the hasport linkage for $50. Prices only valid with purchase of a complete changeover. We can also supply you with 90-93 Integra steering knuckles and hubs for $50 if you need them. Also availabe is the Hasport Aluminum A/C bracket for $160 and the Hasport wiring sub-harness for EF civics that are either HF or Si models (not DX or STD) for $60.
Old Aug 10, 2003 | 02:30 PM
91Teg's Avatar
91Teg
Again from H motors. They are back up so go check em out they have real good prices.
B16A 92-95 (SiR-II) Motor, Tranny, ECU
Price: $ 1799.00 Plus shipping and handling
- Motor
- Hydrolic Tranny (S21, Y21)
- ECU (P30)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
* Please Note: This is not a complete swap. It does not come with axles, shift linkage, or motor mounts
