Here we go again
Old Jul 24, 2003 | 10:46 AM
PHiZ's Avatar
PHiZ
BOOST GOD
make sure your getting your lugs torqued to spec (80 lbs?). I think that will definitly cause problems.
Also, if you caliper isn't retracting your pad entirely, and the pad is dragging, that might cause the problem.
Just tossing out ideas...
-PHiZ
In my experience though, no one breaks out the torque wrench to torque lugs to spec, and that causes problems.
Old Jul 24, 2003 | 10:55 AM
venom903's Avatar
venom903
Brooklyn
well check the rims if you were getting a vibrations for a long time and you didnt do anythingabout it you could have messed up the whole spindel and if so you might need to replace it.if it only started when you installed the rims it could be that the rim is bent or did not come round it" happen" from factory and that is causing the problem try rotating your rims and see if it still doing it, if its not just change lugs and bults the best lugs are the factory one those aftermarket ones strip easy.......................:thumbup:
Old Jul 24, 2003 | 11:49 AM
narib_16's Avatar
narib_16
Keep It Nice, Not Rice!!!
i got new rims too and this happend to me. However i have had them on for 3 weeks now and it seems to be going away. maybe they just needed to be broken in or something?
Old Jul 24, 2003 | 11:51 AM
Jessica's Avatar
Jessica
ch1x0r
Originally posted by 96GreenCivic
yeah they were balance 2xs by the shop, it isnt' alignment ( i dont think ) cause it never happened on my steelies.
it could still be your alignment. if i'm not mistaken, when you've had your tires unbalnced for a while it can screw with your alignment. it happened to mine and i have stock wheels.
Old Jul 24, 2003 | 11:54 AM
dantastic's Avatar
dantastic
cx power!
Originally posted by westcoaststyle
Wheel or you need hubcentric rings to better balance the wheels on the hub. Do a search on vibrates or shakes and you'll get some returns on this subject. It's been covered before and there are more details regarding the possible problems and solutions.
if you do a good job of centering the wheels with the lugs, you might not need the rings sometimes. but i highly reccomend them on your front wheels to eliminate any possibility of vibration.
Old Jul 24, 2003 | 12:20 PM
96GreenCivic's Avatar
96GreenCivic
Wow,.
Thank for all the suggestions!
HAN is a great place
Old Jul 24, 2003 | 01:33 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
This gonna sounds nuts, but could be the problem. The tire might be out of round. My buddy had a wheel balanced 4 times, and it still shook like a biotch. Yes, it was balanced, but the tire being out of round was making it shake. Jack up the front of the car, start it up, and SLOWLY let out the clutch so just the one side starts to spin. (I'm not to blame if you get hurt, or kill someone!) I've done it quite a few times just to check things with no problems. Anyway, with the wheel spinning, you would be able to see any motion up and down, or side to side.
Old Jul 27, 2003 | 11:29 AM
New93Civ's Avatar
New93Civ
I had the same problem and there was a slight crack in the rim
Old Jul 27, 2003 | 05:40 PM
96GreenCivic
Yeah,
Lots of suggestions, thanks to all. This morning I decided to swap the rear to front to be sure that it is the wheel. And guess what? No more vibration! It has to be the rim! I'll tell them to rebalance it and if that doesn't work, I'll tell them to get me another rim. I may be out of round
Thanks HAN
Old Jul 27, 2003 | 05:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
glad to be of service!
